Hi,
I just got my aftermarket 3-pt hitch and I'm thinking I might have gotten the wrong one :-(
As far as I can see, there is now (proper) way I can attach this to my B7001.
If you look at this picture, I would think that the non-adjustable leveling arm (is this what it is called?) should be inverted to what I have installed here but this was the only way I could get the holes to line up and the pins to fit.
I've also installed the arm backwards (IMO) but since the arm 'bends' I can't get it to fit any other way.
So if you look at how it is attached -the arms are no square:
Any advice or help on how I can make this work?
Maybe I should have bought this one (though it says for 25HP):
http://cgi.ebay.com/3-Point-Hitch-Kit-CAT-1-25-45HP-Compact-Tractor-GD-/230616540767?item35b1d1265f
Instead of:
http://cgi.ebay.com/3-POINT-HITCH-KIT-KUBOTA-ISEKI-AND-OTHER-TRACTOR-/330559552352?pt=LH_DefaultDomain_0&hash=item4cf6e27b60
I'm feeling kind of dumb at this point (pun intended) ;-)
Instead of:
