Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 04-07-2011   #1
Guy JR
1st Yr. Apprentice
Default Kubota UDT substitute
Is there any other hydraulic oil that I could use in my transmission other than Kubota UDT. My local tractor supply store carries Valvoline unitrac tractor hydraulic oil-3098 as well as Valvoline anti-wear hydraulic oil-3015. Would either of these be a sutible substitute? Tractor in question is a L1801DT. Thanks.
Guy JR is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-07-2011   #2
Guy JR
1st Yr. Apprentice
Default Re: Kubota UDT substitute
The Valvoline tech line just replyed to my e-mail and according to them, Valvoline Unitrac Hydraulic Oil-3098 is a direct replacement to Kubota UDT.
Old 04-07-2011   #3
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Service Dept Vic has mentioned in the past that you can go to Wal-mart and buy thier brand of UDT and use it just fine. So if you have a great price on something like Valvoline you surely can use that as well. They make some top of the line fluids!
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 04-07-2011   #4
Theekillerbee
3rd Yr. Apprentice
A good quality oil will do. Usually they will say on the back whether it is UDT compatible. Kubota does not make oil. It would be interesting to find out who makes their oil. But I'd be happy putting Valvoline (UDT equivalent) in my tractor.
Theekillerbee is offline   Reply With Quote
Old 04-08-2011   #5
dlumpy5282
1st Yr. Apprentice
I been using a UDT from Tractor Supply in my Deeres and Kubotas for years
dlumpy5282 is offline   Reply With Quote
Old 04-08-2011   #6
Babyfat
2nd Yr. Apprentice
Babyfat's Avatar
It would probably be fine in a DT but I would not use anything but Kubota UDT or Super UDT in a HST, every HST trans we have repair/changed had "Tractor Supply" oil in them, Kubota service advised that they have like 8 additives in their oil that the others do not. The old saying "pay me now or pay me later"
__________________
www.dakins.com
Babyfat is offline   Reply With Quote
Old 04-10-2011   #7
steve l
1st Yr. Apprentice
Equipment: 2 m9000,9540 all cabgmd700 kuhn 605m vermeer,r23a vermeer rake,468 jd baler,
Send a message via Yahoo to steve l
Quote:
according to what i read valvoline makes the oil for kubota tsc atwoods and your local parts store brand name.
steve l is offline   Reply With Quote
Old 04-10-2011   #8
uncle jed
1st Yr. Apprentice
Equipment: 1990 f2100
Valvoline also makes WalMart branded oils
uncle jed is offline   Reply With Quote
Old 06-25-2015   #9
ifpz216
Equipment: MX5100 HST
Valvoline VV813
http://www.valvoline.com/products/co...d-gear-oils/84
Meets or exceeds the following specifications(Where appropriate viscosity grade applies.
John Deere JDM J20C,
New Holland Group(Ford New Holland) ***8211; FNHA-2-C-201.00(134D), FNHA-2-C-200.00(Hydraulic Oil 134)
Massey Ferguson M1129A, M1135, M1139, M1141(PermatranŽIII), M1143, M1145,
Case Corporation(Case I.H., J.I. Case) ***8211; MS-1207(Hy-TranŽ Plus), MS-1210/JIC-143,144,145(TCH Fluid), MS-1209(Hy-Tran
Ultra)
Kubota UDT Hydraulic Fluid, Universal Transdraulic Fluid
ifpz216 is offline   Reply With Quote
Old 06-25-2015   #10
Dr Honda
2nd Yr. Apprentice
Equipment: BX1870
Quote:
Yep... I've used it to top off my tractor when I put on some new hydro equipment, because of his recommendation. I think it was $20 for the 2.5 gal jug.
BUT... I think you can get the traveler brand at the tractor stores cheaper.
Dr Honda is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
