I just obtained a classic 1972 L245. It is awesome.
However, I haven't used it because the oil pressure light stays on.
1. I checked the pressure switch w/compressed air; it works.
2. I installed a pressure gauge in the switch port; measures 15 psi regardless of engine speed. WSM shows oil pressure should reach ~50 psi @ 2800 rpm. Explains why the light stays on.
3. Front of engine was heavily covered in oily sludge, especially around the lower radiator hose. Pressure washed. Day later (w/o starting engine), I noticed oil weeping out from under alternator mount. Upon further inspection, the pocket under the mount was completely filled with oil. Is this normal? Some water was in there, perhaps from the pressure washer.
4. I found TSB#79-07 which mentions a cam plug which can or does come loose causing low oil pressure. A new steel one must be welded in. I've looked over the parts list but can't find. Is this welded into the block or on the cam? Any help is greatly appreciated.
