G5200 (D600) drain cock valve thread pitch
dlundblad
G5200, L2501, ZD1211
May 16, 2009
504
IN
I didn't find a thing online about this so I figured it was worth posting up in more detail. Mine ended up snapping off from the block when I tried removing it during a coolant change.. So lesson learned, use a drill bit, long pick etc. before resorting to removal.
P/n is 15841-73020. About $9 for the Kubota part.
Thread pitch is 1/4"-18 NPT.
This should apply to any G3200 to the G6200 as well as the next generation G1800, 1900 etc. Hope this helps someone.
Steve Corgan
G5200
Jun 27, 2020
Wildwood, Mo. U.S.A.
I wish I would have seen your post before breaking my drain cock off while attempting to remove it. I have the new part now, but I'm confused about the thread size. I want to have the tap on hand before trying to get the piece out of the block. I saw a post on here somewhere that said the thread is 1/4" x 18 BSPT and not NPT. I'd never heard of British Standard Pipe Thread before. Now, I can't find that post so I'm unsure. Can you clear up my confusion? Will the NPT tap work? Thanks, Steve
HamBandit
MLT3060K
Jun 14, 2025
Houston, TX
I can confirm that you can chase the threads with 1/4"-18 NPT tap.
Both the 1/4 NPT brass plug I bought and the OEM Petcock would fit
lmichael
Kubota G2160
Apr 23, 2021
745
359
Rockford IL area
So if the drain cock is NPT threads on this I'll assume same for the D728 in my G2160? And if so any possibility temp sending unit is NPT?
HamBandit
MLT3060K
Jun 14, 2025
Houston, TX
I don't think the threads are NPT, they are BSP
From my understanding, its just the thread angle that is slightly different, so you may get away with whatever NPT changes you want to make
Hugo Habicht
G1900
Jun 24, 2024
850
1,177
Ireland
NPT is 18tpi whereas BSP is 19tpi. Otherwise the diameters etc. are almost identical.
I don't remember 100% what tap I used when making a new drain valve, reusing the inner part.
5,652
Not only is thread pirch different the flank angle on BSP is 55 degrees vs 60 degrees for NPT. They DO NOT INTERCHANGE.
The diameters are close but a $15 caliper from HF will easily differentiate BSP from NPT
Hugo Habicht
G1900
Jun 24, 2024
850
1,177
Ireland
Fair enough. But going through about 7 turns (as on the picture above) with a tap you would not notice that something does not match.
And so far I only found metric or BSP threads on my tractor. I admit, does not prove anything.
5,652
You would not notice but the threads would be imperfect. You can even jam some sizes together right out of the box but the pitch diameters, flank angjes, and in some sizes thread pitch do not match and the threads do not seal correctly. In other words THEY DO NOT INTERCHANGE.
I would expect BSP not NPT on a Kubota diesel engine. Plenty of examples of that in the imported (NA) automotive world.
