Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 02-12-2011   #1
bx1500
1st Yr. Apprentice
Equipment: BX1500, TILLER AND FEL
Default Bx Fuel Filter Problems
I use to change both fuel filters on my bx1500 about every 100 hrs.
with out any problems accuring due to a clogged filter. At that time I
always refueled my kobota at the farm next door. A couple of years
ago the farm was sold. So I had to start getting my fuel in town.
Now about every 30 hrs the filters are done. Ive tried fuel from
three different locations same problem. Two other bx owners in the
area have the same problem. I use power source treatment in the
fuel is there anything else i can do. I don't mind changing filters twice
a year but three times a year that's a bit much.
bx1500 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-12-2011   #2
meanjean
4th Yr. Apprentice
meanjean's Avatar
Equipment: Kubota L1801
Default Re: Bx Fuel Filter Problems
Says a pile about quality fuel.
Find out where the farmer got his fuel.
Maybe there's another farmer who can help a guy out.
meanjean is offline   Reply With Quote
Old 02-12-2011   #3
gktilton
2nd Yr. Apprentice
gktilton's Avatar
Equipment: 79 B7100 w/ FEL, Deere 261 Finish Mwr, Woods M4 Bush Hg, Potato Plow, Cultivator
Quick thought, you have tried 3 different places for fuel, have you changed the container you are getting the fuel in?
Also have you emptied your fuel tank on the tractor and flushed it. You may have gotten crap in the tank once and it just keeps working its way into the lines.
gktilton is offline   Reply With Quote
Old 02-12-2011   #4
Service Dept Vic
Service Dept Vic's Avatar
Ya, all good advice. Changing fuel filters on a BX every 100 hrs is real 'frequent' so something is 'up'.
I can't imagine that Wisconsin sells diesel fuel in a 'standard' that is different from the rest of North America, so start looking elsewhere for this fuel filter clogging up with crap issue.
GKTilton and MeanJean are spot on. The issue is not the fuel.
Check and clean or flush out the tractors tank which in itself is a big job! Consider upgrading the filters to something a little bigger since the OE Kubota inline filters are a quite small. A good Auto/Ag Parts store like NAPA will have about a dozen choices they could show you.
Replace your diesel fuel can with a correct yellow colored approved diesel fuel container and stop using the Power Source fuel Conditioner that you have been using entirely.
It is possible that it's concentration is incorrect or it is in some way reacting with the plastic fuel tank on your tractor or in the container and is creating some kind of plasticizer residue that is coating the filters and leading to their premature failure.
Let us know what you find out! this is an interesting thread that I'll be wanting to follow!
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 02-12-2011   #5
meanjean
4th Yr. Apprentice
meanjean's Avatar
[QUOTE=Service Dept Vic;23938]
I never even considered that.
Old 02-12-2011   #6
bx1500
1st Yr. Apprentice
Thanks all for the input. I think ill remove the tank and clean it out.
Old 04-09-2011   #7
ametcalf
1st Yr. Apprentice
Equipment: BX23
Service Dept. Vic.
I know the weather is getting warm but I wanted to ask before this thread gets any older. If we shouldn't be using Power Source Fuel Conditioner, when the weather gets cold next winter is there a product you would recommend to prevent fuel gelling? I just got a BX23 and my learning curve is real steep right now. I just got a new yellow container but at the same time I got a new grey bottle of the fuel conditioner so I guess I was half right.
Thanks for any advice.
ametcalf is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
