Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Thread Tools Display Modes
Old 02-06-2011   #1
1st Yr. Apprentice
Default Lift arm position lever and control valve questions L3010
Whomever installed the backhoe removed the lift arm position lever so until I get a lever I have to reach under the seat deck to adjust. Since I don’t use the lift arms for anything where should the position lever be placed? All the way forward, back, or somewhere in between. It seems to me at one point my loader bucket wouldn’t go down and I had to adjust this lever, does this lever have anything to do with the loader hydraulics? With the tractor at idle I pushed the lever all the way forward, when the lift arms stopped at the top of the travel range there was a loud pop like something broke, sounded similar to a pin being sheared. For now I am running the lever about in the middle of its range.
What does the control valve adjustment under the seat actually control? The volume or pressure of hydraulic fluid? Could this possibly have anything to do with my bucket lowering fast and jerky?
rodburner is offline   Reply With Quote
Sponsored Links
Old 02-08-2011   #2
New Member
Default Re: Lift arm position lever and control valve questions L3010
I have a L3010 with a BL4690L (3pt hitch mount) backhoe. You are correct that the tractor's 3pt hitch "position control" lever does need to be in the forward or down position. Otherwise, if left in the up position, this will attempt to drive the rear lower lift arms up against the backhoe mounts and cause the hydraulics to "overload". This causes the front end loader to act exactly like you describe (not going down consistantly). This will happen on mine everytime! Obviously, this is not good for the hydraulic system.
As far as the "control valve adjustment" under the seat, I'm assuming your referring to the "3 pt hitch lowering speed" knob. I don't know if it could effect your FEL bucket speed or not, as I would guess your "position control" lever is your issue.
I included a quick scan of my manual's "Hydraulic Unit" pages for your reference.
Hope it all helps...
Click image for larger version
Name:	L3010 Hydraulics.jpg
ID:	2994   Click image for larger version
Name:	L3010 Hydraulics 001.jpg
camonica is offline   Reply With Quote
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
