Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 01-05-2011   #1
TrippeTree&Timber
1st Yr. Apprentice
Equipment: Kubota B6100 4wd
Exclamation B6100 Leaking Fuel
I have a B6100 that i got a good deal on, but it needed some tlc and works great now. The only problem is it leaks fuel where the 3 ports come out of the injector pump, and a little where the injectors go into the cylinders.
I am not too concered about the small fuel leaking around the injectors(its a 30yr old tractor) but the fuel leaking around the ports from the pump is enough to create a small puddle on the garage floor. (which im getting sick of cleaning up)
There is no lack in performance or anything else, but i was wondering if this leak could cause any unseen damage, and how do i fix this problem(there must be gaskets that need to be replaced right?) And lastly if i was to take it apart how hard is it to crack the lines to the cylinders to bleed out any air that would enter the system.
Any help on the matter would be much appreciated.
TrippeTree&Timber is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-05-2011   #2
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Default Re: B6100 Leaking Fuel
Yeah I'd say check into a gasket kit or worse comes to worse might have to replace the pump. As far as cracking the injectors take two line flair nut wrenches and crack em open. One wrench will hold the bottom of the injector still and the second wrech you twist the top open where the metal tube comes in and has the flair nut on. Pretty simply!
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 01-05-2011   #3
TrippeTree&Timber
1st Yr. Apprentice
Alright Sounds Good Thanks
Old 01-05-2011   #4
buildspacetrains
1st Yr. Apprentice
Equipment: L2402dt
A word of warning, don't pull the injector pump apart unless you know what your doing! A friend of mine had fuel leaking from the pump throttle and shut off levers, (massey tractor) so he got a O ring and gasket kit and pulled it apart. He's still finding bits and pieces on the shed floor and wondering where they go!
buildspacetrains is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
