Here is the problem I was pushing around some brush and my oil psi light started flashing. pulled the tractor over to the barn and decided to change the oil and filter(hadn't done it yet this spring). filled it up with Rotella 15w40 and started the tractor while it was idling no light as soon as it was raised above idle the light came on. If you let the tractor sit you can start it and the let it idle and the light won't come on but as soon as you come off idle it comes on and stays on. I'm thinking oil bypass valve, so i take it off and press down on the ball in the end and it presses easy (not 60 or 70 psi like i thought it should) so i order a new 1 and it has the same ball on the end and presses just as easy. The dealer that the tractor was bought new from is who I've been dealing with he said couldn't be the bypass because he hasn't ever sold 1 until now.
Maybe more info here the tractor is a 83 was bought new by my dad and has 1300 hours on it.
I also asked the dealer about the cam plug problem and he said couldn't be that because (you guessed it ) he hasn't sold any, Bring the tractor in and they will rebuild the motor for me it has to be the bearings that are bad. The motor has never made a sound and still doesn't.
So here is what has been done so far.
1. Changed oil and filter
2. Cut top off old filter and looked inside, no metal
3. Removed front cover to have a look and see if plug was in front of cam, it is.
4. Removed oil pan and had a look in there no metal and is clean. Had a look at the oil pick up screen and nothing blocking it. Gave the rods and mains a shake and nothing seamed loose.
5. Put front cover back on and hooked up a old fuel oil pump to the stub that the oil filter goes on and primed it with oil and turned it on. Oil dripped from the mains and rods. Oil was running back trough the hole in the block from the front cover area. Looked inside the cover from the throttle hole and could see oil squirting from the gear in the center. Was showing about 3 psi on the gauge i have hooked where the sending unit for the oil light goes.
6. Pulled front cover again and had a look inside and looked at the gear that was shooting oil and the hole is a factory made hole. Also noted that there was a lot of oil on the front of the cam so looked closer at the cam and the plug has 2 holes in it.
So here is where i stand, I don't think the holes are supposed to be there.
Also if the front plug is bad should i change the rear also. If so what is the best way to do it remove the motor and go trough the back or pull the head and and valve train and remove the cam that way?
Here is a picture of the cam so you can see what I'm dealing with.
If you need higher res. pictures i have 1.
