Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Tractor Operating
Tractor Operating Wondering what that strange lever does, how to safely hill climb or get into 4WD? Discover and share how to get the most out of your tractor.
Reply
Thread Tools Display Modes
Old 06-27-2009   #1
regularjay
1st Yr. Apprentice
Equipment: B7200E
Default B7200 Possible Compression Release Control ???
I am new to the Kubota world and have recently purchased an old B7200E. Under the steering wheel next to the fuel shut-off is another pull out cable (presently broken) that looks as if it is supposed to actuate a lever that sticks up from the rear of the cylinder head. Being as the cable is broken it does nothing now, I cannot move the lever by hand and didn't want to break anything by applying any force. I can find no reference to this in my copy of the operators manual for the tractor. I am wondering if it might be a compression release. Tractor seems to operate fine anyway but I am quite curious as to what this might be.
Thanks in advance for your input.
Jay
regularjay is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-27-2009   #2
dusty-t
4th Yr. Apprentice
dusty-t's Avatar
Default Re: B7200 Possible Compression Release Control ???
Hey Jay. Yes that is the cable for the decompressor.Mine has been seized for years and the tractor starts fine,
dusty-t is offline   Reply With Quote
Old 06-27-2009   #3
Service Dept Vic
Service Dept Vic's Avatar
Yer supposed to replace those worn and broken parts on yer Kubota Dusty-t!!
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 06-28-2009   #4
regularjay
1st Yr. Apprentice
Equipment: B7200E
I kinda figured that's what it might be. Anyone have an idea how much "persuasion" I can safely use to get it moving again?
Thanks,
Jay
Old 06-30-2009   #5
Service Dept Vic
I've removed them and then submerged the cable and sheath in penetrating oil and then worked to free the cable up after a few days.
The replacements are 20-25 bucks.
__________________
Old 07-01-2009   #6
regularjay
1st Yr. Apprentice
Equipment: B7200E
The cable is shot altogether what I'm curious about is how much force I can put on the release lever on the head itself as is seems to be frozen.
Old 07-02-2009   #7
Service Dept Vic
Remove the valve cover and free it up with a good cleaning in solvent. They can get gummed right up if not used over time. Too much force will actually bend the lever without rotating the cam.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
