Finally time to let the old girl go to a new home. Have owned it over 30 years and primarily used as a lawn mower. This is strong little tractor that has never failed to start. Always garaged, so tractor is in good condition, especially given it's age. Mower deck is in fair shape. The deck is rusty but everything works. Replaced belt tension adjuster. Seat rusted out, so I had the seat pan welded in, which you'll see in pictures
B6000 4X4 with Mid Mounted Mower (MMM)
2 Cylinder ZL600 motor
6 Speed Forward/ 2 Reverse - Hi Low
4WD with locking differentials
Mid Mounted Mower run off front PTO with electric clutch to engage.
Plumbed secondary hydraulics actuator (lever is stuck because I don't have any other implements)
Not exactly sure what year it is, I believe its 1977, but have owned it for over 30 years. I am in Southern New Hampshire. Pick up preferred, but could possible deliver or meet part way.
REDUCED: Asking $2700 or BRO
NOTE
lease do your reading on the B6000 as the PTO turns in the opposite direction, so most 3PT PTO Driven implements will not work without a reverser.
NOTE
