Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 11-12-2010, 09:32 AM   #1
bigdg
New Member
Equipment: B7200Hst w/ RC 60 mower deck
Default Installing a temperature gauge on B7200
Does anyone have experience with installing a temp guage on a B7200 HST or similar ? My dealer says he can do it and I don't like running any diesel without one. Thanks in advance for your input.
bigdg is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-12-2010, 05:27 PM   #2
bruceatlam
Equipment: B20, FEL, box blade, flail mower
Default Re: Installing a temperature gauge on B7200
Installed one in the upper radiator hose in my B20. Cut the hose and installed a purchased fitting in the hose with standard hose clamps and then mounted the sensor in the fitting -- works like a champ.
bruceatlam is offline   Reply With Quote
Old 11-12-2010, 05:44 PM   #3
kuboman
Quote:
There are temp gauges available that have a sensor that can be bolted to any part of the head or thermostat housing. They pick up the temp off the head so you don't have to get into the water jacket. Seems like a good alternative if finding a suitable port to screw in a sensor is a problem.
kuboman is offline   Reply With Quote
Old 11-13-2010, 01:38 PM   #4
DsBota
DsBota's Avatar
Equipment: B8200, G1800
The B7200 engine is very similar to the B20 just a little smaller. Upper rad hose would work great.
__________________
Dion
DsBota is offline   Reply With Quote
Old 11-14-2010, 06:27 PM   #5
bigdg
New Member
Smile Re: Installing a temperature gauge on B7200
Thanks for the help guys. I'll work with the dealer and see how he wants to do it. Where did you mount the guage itself? DG
Old 11-14-2010, 06:56 PM   #6
DsBota
DsBota's Avatar
I've seen this done before on a B8200.
Click image for larger version
__________________
Dion
Old 11-15-2010, 07:32 AM   #7
bruceatlam
Quote:
Attachment 2428
Looks just like the gauge panel that I used. I mounted mine to a loader support bar that runs across that cowling about steering wheel high --- to the left of the steering wheel. Worked for me cause my loader is a permanent fixture.
Old 11-15-2010, 05:37 PM   #8
aquaforce
aquaforce's Avatar
Equipment: L175
I tapped a pipe taper hole in the cylinder head cover on my L175 and installed an electric guage system. It is so great. I really love it.
ID:	2438   Click image for larger version
ID:	2439   Click image for larger version
__________________
Smart: Knowing exactly what to do right in a bad situation.
Wise: Knowing how to avoid a bad situation.
AKA: Captain Candle Wax
aquaforce is offline   Reply With Quote
Old 11-16-2010, 08:16 PM   #9
Service Dept Vic
Service Dept Vic's Avatar
Equipment: B-5000
Aquaforce, very nice job!
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 11-17-2010, 06:45 AM   #10
dunk
1st Yr. Apprentice
Equipment: ZB6001
Hi All
I like what aquaforce has done.
Would this work on my B6100, and if it would what is the ideal temp to run with?
Many thanks
Duncan
dunk is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
