Backhoe dolly
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
Bought a BH65 backhoe for my B2620 so now i have more projects .
Started with a simple T frame but that does not allow the bottom of the boom to pivot down enough to unseat the bottom pins so had to add the vee section. Will update as i refine this..
Sent from my SM-N900V using Tapatalk
edit; well i see the picture i attached when i posted this from my phone didnt attach.
bearskinner
Sep 1, 2014
925
240
N. Idaho
I picked up a couple of the HF movers Dolly's, measured the footprint of my Hoe with the stiff legs up, attached a couple 2x4's to the Dolly's than put plywood on the 2x4's. Kinda a T or Y shape. Remember to strap the legs once there up, as they will come down in a couple days. The nice thing on wheels you can move it around the shop to keep it out of the way.
bikerdib
L4701 with FEL, BH92 backhoe
Oct 5, 2010
210
14
Wallis, Texas
If you have a welder or know someone that does maybe you can make something similar to the one I made. Only thing I'd do different if doing again, I would get steel wheels, I think the rubber ones I used make pushing the cart around a little harder that steel ones would. And no, the BH isn't that shiny and clean anymore. That was right after I brought it home from the dealer.
poyjas
B7100HST & B2650 TLB-LandPride grapple & 60"BB
Jul 20, 2016
39
Hayden ID
Good ideas, guys. I see something like this in my future.
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
40
KY
Any pics of your setup?
jajiu
Jun 5, 2016
454
111
Rowley, Massachusetts
I made my dolly out of wood, some 2X8 boards I had and used stove bolts to put them together and used 9-3" steel casters, 4 on the bucket support and 5 on the main body support. I used 1 1/2 X 1 1/2 Angle Iron I had. The overall length is 8' and the bucket support is 18" X 18" the main body support is 36" X 22" and attached to the Angle Iron by lag bolts. Still too heavy to move by hand, or I'm just a weakling, but I can push it with the bucket of the tractor.
MattN03
Sep 5, 2016
222
40
KY
Any ideal what a BH76 weighs?
bandaidmd
May 19, 2013
603
Middle of DELMARVA
well the picture posted this time ~sideways lol~
i will be adding a trailer coupler and a couple tabs to keep the bucket from sliding off the tube. Went with rubber wheels because my storage area has a gravel floor so i will either tow it out to the concrete or hook it to the tee handle trailer dolly.
Picking up a thumb from the K dealer today. BX exp. said they will have one coming out maybe next month with a hydro option but i'm impatient.
MattN03
Sep 5, 2016
222
40
KY
I'm out of state visiting kids. I can take some pics when I get back.
EDIT: It's North Idaho Wolfman magic! :p
Do you remember the size or weight capacity of the dollies? Does it roll pretty good?
jajiu
Jun 5, 2016
454
111
Great Idea to add a trailer hitch to the dolly, I'll see if I can do something to mine, It's too heavy to move by hand, my BH92 must weigh about a ton.
bearskinner
Sep 1, 2014
925
240
N. Idaho
They advertise 1,000 lbs per dolly, I use two on each, for the hoe and loader. They roll really easy on concrete. It's great for moving from side to side in the shop
MattN03
Sep 5, 2016
222
40
KY
Thanks bearskinner! That gives me some great ideas!
jajiu
Jun 5, 2016
454
111
Had to add a third pad to my backhoe dolly due to the hydraulics settling. Needed to add support for the pivot point, now all I have to do is put some sort of hitch on it so I can move it easier.
