Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 05-29-2009   #1
rba
New Member
Equipment: L2550
Default Valve Adjustment For L2550
Hello Vic,
I have recently discovered your very interesting forum. I have a L2550 with about 500 hours accumulated over 22 years. The tractor has never been in the shop for professional service but still continues to run great. The only problem has been a considerable accumulation of rust debris in the fuel tank. I have recently cleaned and refurbished the tank with Red-Kote fuel tank liner.
The Operator's Manual says to have the Kubota dealer check the "valve clearance". I have adjusted the valves on a small gas engine (Kawasaki Mule) but have never worked on a diesel. What is involved in checking the valve clearance on a L2250?
Thanks, Ray
rba is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-01-2009   #2
Service Dept Vic
Service Dept Vic's Avatar
Default Re: Valve Adjustment For L2550
Ray,
Leave that engine alone!
500 hrs is a nano second of run time on that engine.
Tell you what. When that L2550 shoots a hot valve spring up onto your lap as you're rototilling the garden, I'll advise how to adjust the valve lash clearance on that 3 cylinder bad boy.
But you'll need to put a few thousand more hours on that engine first!
I'ts not required right now Ray. Use at will!
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Reply
Tags
l2250, valve adjustment, valve clearance
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
