Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Implements & Attachments
Implements & Attachments Find everything related to operating, servicing and maintaining that loader, mower, blade, snow blower, tiller, hitch or scraper, right here.
Reply
Thread Tools Display Modes
Old 07-16-2010   #1
digdug
1st Yr. Apprentice
Equipment: L5240HST, loader, 6'brushog, boxblade, 100gal spayer, 8' graindrill, and more.
Default Roto-tiller chain or gear driven?
I'm going to buy a roto-tiller for the Kubota to use for garden prep and to use wildlife food plots. What are the pros & cons of a chain drive and a gear driven roto-tillers? Any other advice on purchasing a roto-tiller would be appreciated.
digdug is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-17-2010   #2
Theekillerbee
3rd Yr. Apprentice
Default Re: Roto-tiller chain or gear driven?
Most are a combination of both. Usually the gear drives are reserved for the higher end tillers. I've not heard of anyone loosing a chain, as it is usually the gear box up on top where your PTO hooks in that goes bad.
Theekillerbee is offline   Reply With Quote
Old 07-20-2010   #3
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
My brother had a King Kutter brand tiller that was all gear drive and I have a Bushhog that is chain drive. The KK gave no trouble and neither has the Bushhog. A all gear drive will mean you have another gear box to change oil in and maintain with is no big deal. After the initial chain tention adjustment and adding grease for chain lubrication I have never needed to do anything else to me chain drive. If you buy a quality built tiller I don't see any problems with either type.
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Old 07-27-2010   #4
Marty394
1st Yr. Apprentice
Equipment: L3010 w/ Cab, RCR 1560, RB 1584, SMC Loader, KK II 60" Gear Drive Tiller
I have the King Kutter 5' gear dirven model, and it has worked well. I use it for food plots, and gardens also. This last spring it put in a 6 hour day of tilling our food plots in some pretty nasty conditions (slipped the pto clutch three times) and it worked great.
Bob
Marty394 is offline   Reply With Quote
Old 08-01-2010   #5
Mingy
2nd Yr. Apprentice
Equipment: L3010 backhoe FEL, B2300, M9000
Mine is a 4' side shift with a gear final drive. Made in Italy.
The chain drive is in an oil bath, which is, as I understand the way chains are supposed to be. A chain in an oil bath last a long time while one 'out in the open' like my haybine, and baler wear out quickly. Lots of vehicles use chain for timing and last as long as the engine does.
In terms of advice, I'd suggest not going too big. With a side shift tiller you adjust it so it tills behind the right wheel.The thing with a PTO tiller is, it does a lot of work real fast so, unless you are doing this for a living there isn't much benefit from going big. Every spring I till my garden (about 1/2 acre) and a few of the neighbour's as well in less than a couple hours. Of course, if you have nice soft soil, big isn't bad, but we have rocky stuff that gets real hard.
Oh yeah - make sure you get one with a slip clutch PTO, otherwise, any rocks and you'll shear a pin.
Mingy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
