Re: Jerky emplement lift
Thanks for the info. I have previously added hydraulic fluid because the previous owner had a hydraulic hose blow off and the fluid was low by about 2gallons. I did not check the filter screen, however. I have been reading about changing the filter and found I will need to capture a lot of fluid and reuse it.
I will try this idea first.
