Exactly what the title says. It was starting to get stiff in pushing control level into that mode. Finally, won't click into that function mode anymore even with moderate force. Boom up/down operation is fine and smooth. Roll operation is a-okay as well.
I obtained the WSM on that Loader. Basically useless WSM and mentions nothing if/when/why you're having trouble with the float function in the troubleshooting section.
Had a service parts guy at my Dealer say something about there could be water/moisture/rust inside control valve. My logic says that can't be, being inside there's hydraulic fluid. Plus my Kubota is not stored directly out in the elements. Stored outside, but under cover out of direct rain or snow contact.
Before I start digging into the control valve blindly, any insight in what to expect and what to be careful about and/or what's the cause of losing only the bucket float function?
Thanks in advance
Thanks in advance
