Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 06-04-2010   #1
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Default Bushhog, Gearbox or spindle.
I have a slight booboo with my bush hog and I'm not sure if I need to replace the entire gear box or just a spindle. It took a helluva hit a while back and the bush hog wobbles like crazy all over the place. I looked underneath there today and I could grab the stump jumper and shake the entire blade assembly side to side and see it wobble at the spindle. So I'm not sure if I can get away with just a spindle or do I need a whole new gear box?
I reckon I'll crawl under there in the am and take a better look at things.
Thanks kids!
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-04-2010   #2
Sam427
2nd Yr. Apprentice
Equipment: L3410 GST, FEL, Bush Hog, Box Scrape, Spreader
Default Re: Bushhog, Gearbox or spindle.
I hit a buried cable with my Woods and it sheared the input shaft off. They wouldn't sell just the shaft, I have to buy the whole gearbox. Lesson to all with a slip clutch and the shear bolt, used equipment may not have the correct parts in them, mine had a grade 8 bolt in it, and the clutch was froze up from sitting out in the weather, viola, broke shaft!
Sam427 is offline   Reply With Quote
Old 06-04-2010   #3
Eric McCarthy
VIP Service Tech
Agri Supply has a gear box pretty cheap for about 100 bucks. I wasn't sure if the spindle could be replaced or if I had to replace the whole gearbox. So it looks like a new gearbox is in the future.
THANKS!
__________________
Old 06-04-2010   #4
thirtyacres
1st Yr. Apprentice
Equipment: L185
Quote:
So........what grade shear bolt should be used on brush hogs........and how do you tell the grade number?
Thanks.......bob
thirtyacres is offline   Reply With Quote
Old 06-04-2010   #5
Rust Addict
1st Yr. Apprentice
Equipment: B6000E
Hold up on them new parts for just one second. Have you pulled the box off of there yet and tried to get you hand on just the broken part? If it is a clean snap on the shaft and you far enough from the seal diameter and spline you could look at a weld repair. If you not tooled to do it yourself, find a local fabricator, they may be able to get you going again for dirt cheap.
I've only ever know shear pins to be one grade, SOFT. These have the two little rings where you usually see all the bolt threads.
Rust Addict is offline   Reply With Quote
Old 06-04-2010   #6
Eric McCarthy
VIP Service Tech
I have not got that far yet. Just looking for some ideas on what needs to be done. The bush hog as a stump jumper on it and that has a pretty nasty blend on it which I assume would need to be straightened back out. I can grab ahold of the stump jumper assembly and shake the hole thing side to side pretty far. I had hopes of taking the gearbox off and seeing if I can get it welded back together perhaps.
__________________
Old 06-04-2010   #7
Sam427
2nd Yr. Apprentice
Quote:
Thanks.......bob
Most of the shear bolts in any piece of equipment are Grade 2, at the very absolute most, a Grade 5. The equipment comes with the correct size bolt and grade, so as to shear the bolt instead of damaging the equipment. I bought a box of grade 2 bolts for my post hole digger, digging in rocks usually breaks quite a few, I have broke as many as three in one hole before. At least it just shears the bolt and not break something though.
Old 06-04-2010   #8
ipz2222
Journeyman
Equipment: L235, bx2670
Sam, grade #'s. SAE bolts "american' have hash marks on the socket head end. 3 hash marks is grade 5 and 5 hash marks are grade 8. Most grade 8 bolts are also yellow cadmium colored.
Metric bolts have a number in the end. 5.8 is low grade and 8.8 medium and 10.8 is high grade.
ipz2222 is offline   Reply With Quote
Old 06-05-2010   #9
Sam427
2nd Yr. Apprentice
Most of the grade 8 we use are just black oxide. There is a 12.9 grade in metric as well.
Old 06-05-2010   #10
Will In Tx
3rd Yr. Apprentice
Equipment: L3400 HST/FEL, Box Blade, RTV 900 Camo, ZD323 Zreo Turn Pro Mower + More
Quote:
Eric,
That is what I would do to make sure you really know what your dealing with.
Hope it works out less $$$$
Will In Tx is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
