Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Thread Tools Display Modes
Old 06-01-2010   #1
1st Yr. Apprentice
Equipment: Ford 9N, Kubota B6000 with FEL
Default Greasing B6000 clutch release/throwout bearing
I just got my B6000 basket-running, barely in time for the visiting grand kids to have a great time riding around on it. It sounds like the clutch throwout bearing is making noise. There has been a lot of discussion on greasing throwout bearings, but when I searched I didn't find anything on a B6000. There is a hole in the tractor "tunnel" that should line up with the throwout bearing, but I see no grease fitting there. I've looked up from underneath (someone had commented the bearing could be installed 180 degrees out of position on some tractors) but I don't see anything that looks like a grease fitting. Does the B6000 have a greaseable clutch release/throwout bearing? If it is supposed to, are there some after-market bearings that don't have grease fittings?
Thanks for the help.
GpaG is offline   Reply With Quote
Sponsored Links
Old 06-01-2010   #2
3rd Yr. Apprentice
Equipment: Kubota B7100HST-E
Default Re: Greasing B6000 clutch release/throwout bearing
On my B7100 if you look on the left of tractor in front of clutch pedal at bottom there is a hole in the side panel cut out round appx 1.5 inches round. Use a flashlight look in there that is where mine is dont know if yours is the same. Hope this helps.Its about 3 inches deep.handy
handyman is offline   Reply With Quote
Old 06-02-2010   #3
Equipment: L235, bx2670
Greasing the throw out bearing does not actually "grease the throwout bearing". What you are greasing is the slideing part that holds the bearing to the front trans collar. The foward and aft movement.
If the bearing is makeing a noise, it will have to be replaced, along with a new clutch and pressure plate.
ipz2222 is offline   Reply With Quote
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
