Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 05-30-2010   #1
sgschmir
New Member
Question trouble with hydraulic quick connects
I am having problems getting my BH hydraulics reconnected; when i try to hook up the line from the BH to the tractor I can't push it in quite far enough to conncect, the connectors are clean and not damaged? When I reconnect the tractor line back into the tractor receiver it connect ok, but the BH one i cannot quite get. Is it something to do with the particular position of the connector when I disconnected? is there a way to relieve that so I can connect it easily? How do you avoid getting into this situation to begin with? Thanks for the help. 2630/BH
sgschmir is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-30-2010   #2
bruceatlam
3rd Yr. Apprentice
Equipment: B20, FEL, box blade, flail mower
Default Re: trouble with hydraulic quick connects
Take that male QD and wrap in a rag and then push the ball against something to relieve the pressure --- wrap in a rag so you can catch the sqirt of hydraulic fluid and avoid making a mess. If your BH is sitting out in the sun or in a hot shed, the pressure will build a little after you disconnect. That makes it hard to reconnect without relieving the built up pressure.
bruceatlam is offline   Reply With Quote
Old 05-30-2010   #3
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
I used to run a forlkift that you could take the forks off and put a scoop bucket on. We had to turn the lift off and leave the key in the on posistion and then wobbel the joystick all around to get rid of back pressure in the hyd lines. The quick connect lines would never hook up unless you wobbeled the joystick. Maybe try shaking the loader controls all around and play with the 3pt lift lever and see if that might run fluids back down when the tractor is off.
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 05-30-2010   #4
sgschmir
New Member
thanks for the tip, worked great, lots easier
Old 08-02-2010   #5
John Pollock
New Member
Equipment: B2920HSD,RCK-60-29B Mower, LA364FEL,Land Pride LR-05 Landscape Rake,
I just spent the better part of the weekend trying to hook up a new FEL that I had removed with the tractor running, not knowing to relieve the hydraulic pressure first. I tried all the tricks like turning the switch on and moving the control arm around. The pressure on the tractor side was not the problem as I could easily depress the plungers on the male fittings. The FEL side was another story as 2 of the female fittings would depress easily and 2 would not move with any kind of pressure I could apply. I finally called my dealer and was told to insert a 6 inch x 3/8 bolt into the female fitting and strike it with a hammer to relieve the pressure. Worked like a charm. If I did it again, I would wrap a rag around the fitting and lower part of the bolt and wear safety glasses before applying the hammer as the burst of fluid that comes out can be intense. Once the pressure was relieved, the connectors were easy to snap into place. I hope this makes somebodys weekend go a bit better than mine did.
~ John
John Pollock is offline   Reply With Quote
Old 04-27-2014   #6
ctfjr
New Member
Equipment: L3400HST
Quote:
I know this thread is really old but. . .
I just want to thank bruceatlam for this reply I haven't had my backhoe on the L3400 in quite a while and could not get the quick connects to seat fully
I turned off the machine & relieved the pressure on the front bucket - well apparently not all the pressure I let the tractor sit overnight and easy peasy, they connected without any difficulty.
You have to love the interwebby
Thanks again!
ctfjr is offline   Reply With Quote
Old 04-27-2014   #7
BotaDriver
3rd Yr. Apprentice
Equipment: L3800dt
If the connectors on it cannot connect together, consider swapping them out for some that can. When you go to hook them back up to the tractor, disconnecting them should bleed out enough of the pressure to be able to hook it back up to the machine.
__________________
YeeHaw!
BotaDriver is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
