Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 05-22-2010   #1
chipdip268
1st Yr. Apprentice
Equipment: B1750HST, Brantley Backhoe, LA300 FEL
Default 3 Point Hitch problems
Hi all.... I have a problem with my 3PH lift... with an implement on it you can raise it just fine but then it drops a bit and starts "cycling"... raise, lower, raise,lower.....etc. Shut the tractor off and it drops. FEL is working just fine, just the 3PH is giving me issues. It has about 2200 psi on the guage at the FEL and you can watch it up and drop while the 3PH is doing its thing.... Any Thoughts? Is this just an adjustment or do I need to tear into the control valve?
chipdip268 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-22-2010   #2
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Default Re: 3 Point Hitch problems
Its not the control valve because there is just one big hydraulic piston is there that does the work. Its much like the piston on an engine. Try turning the flow controll knob that infront of your seat and see what that does.
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 05-25-2010   #3
chipdip268
1st Yr. Apprentice
When I turn the flow control valve under the seat it either does the cycling or it just hangs there.... the implement won't go down unless I readjust the flow control knob. No matter where the lift control lever is at. It seems as though when the 3 point lifts up, it stops where it should and immediately starts to float down even though the lift control lever has not been moved, and once it drops an inch or two, it automatically raises it back up to the same spot and keeps doing this over and over. Like maybe the feedback rod is moving when it is not supposed to... but it doesn't have any play and has not been messed with. It just started doing this suddenly.
Old 05-25-2010   #4
Service Dept Vic
Service Dept Vic's Avatar
Check to make sure that where the control rod rotates the lever going into the piston case, is tight. Sometimes the shaft can turn or slip inside the clamp fitting. Short of that, you may have a scratched spool valve on the three point, and that's common.
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 05-25-2010   #5
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
I had this happen to one time to my L 3000. I had the flow control set where it would fall slow. I don't know if it had a piece of trash get caught in it or what. I opened the flow control all the way up and cycled the lift up and down several times and then reset it and the problem went away. It was about 8 yrs ago that mine did this and has never done it again.
Have you ever changed the hydraulic oil yet?
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
