Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Tractor Operating
Tractor Operating Wondering what that strange lever does, how to safely hill climb or get into 4WD? Discover and share how to get the most out of your tractor.
Reply
Thread Tools Display Modes
Old 05-19-2010   #1
tiger9297
1st Yr. Apprentice
Equipment: B7100HST-D w/ Bush Hog FEL
Default B5100E hydraulics question.
I'm looking at a B5100E. I've actually had one before, along with a B7100HST-D that I currently own, and they are fun little tractors. However, the B7100 has a square "block" in the hydraulic lines where you can bolt on an outlet for adding external hydraulics. The B5100 I had did not have this "block". Is it possible to add this "block" to a B5100? I'd like to buy this tractor, but the main reason I need it is for running a firewood splitter, so I will have to have external hydraulics. Thanks for the help.
tiger9297 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-19-2010   #2
Green Mountain Slim
2nd Yr. Apprentice
Green Mountain Slim's Avatar
Equipment: B8200D, Woods LS84 FEL, Woods BH6500 BH, Farm Force 5' GB.
Default Re: B5100E hydraulics question.
What type of wood splitter are you thinking of using? The ones I've seen locally are run off of the PTO and have their own hydraulic system so you don't need the auxiliary hydraulics. Like this one.
http://www.logsplittersales.com/p36-...12ab971e6724ed
I wouldn't worry about adding the hydraulics, but if it's possible and you have other uses for it as well Vic might be able to tell you what you need to do.
Green Mountain Slim is offline   Reply With Quote
Old 05-25-2010   #3
Service Dept Vic
Service Dept Vic's Avatar
You'll need to cut into the high pressure line off the pump, and divert hydraulic power to your aux control for your splitter. Simple loop, easy to do and very price effective.
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 05-26-2010   #4
tiger9297
1st Yr. Apprentice
Quote:
It's "easy to do" depending on who you are. For you, I'm sure it is a very easy "fix". However, I need a little guidance on this. Without the square "block" like my B7100 has, I'm not really sure what to do. If I start cutting hydraulic lines, I'm going to need something to go there to plug them back up. Is there anywhere I can go to find out how to do this? What parts to buy? Where to buy? Are these Kubota parts?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
