Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 05-18-2010   #1
B6200Dave
1st Yr. Apprentice
Equipment: B6200 HST
Default B6200 Hydraulic Pump Rebuild Question!
Hi All,
I was wondering if someone could help me with a potentially "stupid" question . I recently re-built the hydraulic pump on my B6200 (all new O-Rings etc) and when i put it all back together I could turn it by hand but it was very stiff, hard to turn but there was no grinding noise etc so I didn't worry about it at the time. I put it all back together and it is working all right but then I started wondering if the two spindles / pumps were properly seated because it would not spin freely and was it going to cause some damage.
A little more background is that when I removed the pump the slot on the engine that the drive gear from the pump fits into was a little worn ... I really don't want to make that worse by the pump not spinning freely. So, very long winded way of asking ... should the hydraulic pump spin freely by hand or was the stiffness normal after the re-build
All and any comments are greatly appreciated!
Thanks!
Dave
B6200Dave is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-18-2010   #2
stanleyp
New Member
Equipment: L345
Default Re: B6200 Hydraulic Pump Rebuild Question!
I will be rebuilding my pump this week, but when I took my hydraulic pump off, it was a little stiff turning the shaft by hand. I can turn it, but it is stiff. I would think it should be if you have a good seal. I will let you know if mine is still stiff after my rebuild.
Was it loose before you rebuilt the pump?
stanleyp is offline   Reply With Quote
Old 05-18-2010   #3
B6200Dave
1st Yr. Apprentice
Hi Stanley,
Thanks for the reply ... unfortunately in my haste to get the job done I never checked it before the rebuild (my issue was with leaks and not how it was functioning). However, I believe you are right that with a good seal it should be tight ... I am interested to see what yours ends up like.
Thanks!
Dave
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
