Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 05-16-2010   #1
rscorey
New Member
Equipment: B20, Loader, Backhoe, Tiller, Mower, Post-Hole Auger
Default B-20 Hydraulics Quit on Backhoe
Friends: New to this forum. I have been unable to get my BT 750 bakchoe arm to swing so I need to take it off of my B-20.
Arm was full left (from operator's seat) and I couldn't move it to center for unloading so I cracked the hydraulic lines to one cylinder and was able to center it. I lost maybe an ounce or so of fluid. Arm now moves freely back to far left but won't push beyond center so I assume there is pressure in one or both of the pistons.
I started the tractor intending to raise the leveler arms, curl the bucket and move the tractor to the removal spot. But I don't seem to have any hydraulics in the backhoe unit (BH) - no movement in the levelers, bucket or arm in and out - which means I can't disconnect and unload it. But I can raise and lower the front end loader so I do have hydraulics.
The quick connects to the BH unit were connected when I bled the pressure to the piston. Oil level appears to be between the marks on the dipstick so what should I try next? Do I have air in the lines I need to bleed somehow?
I have looked at a ton of messages on this forum but I know very little about hydraulics. Any help would be appreciated so I can get the backhoe off and my mower on.
Once I get this fixed, I would also like to know if anyone has been able to deal with the auto-return/arm failure on the BT750 backhoe. Dealer want $1800 to replace all of the valves. I just need to bypass the black box to the the two solonoid controlled valves that swing the arm.
Thanks for any who can help a novice. Have a great day!
Scott
rscorey is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
