Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 05-15-2010   #1
twomanyprojects
1st Yr. Apprentice
Equipment: L225
Thumbs down Help -3-pt. hitch won't lower (with load)!
Having more problems with my L225 with backhoe mounted on the 3-point hitch. I recently changed the hydraulic fluid and cleaned the filter, now the 3-point hitch will raise, but not lower. The control linkage from the lift arm to the control lever is not the problem, it just won't go down with the lever forward in the down position.
Any ideas where to go from here? The backhoe and 3PH seem to be all the way up, and nothing goes down.
Thanks
Frank
twomanyprojects is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-15-2010   #2
ipz2222
Journeyman
Equipment: L235, bx2670
Default Re: Help -3-pt. hitch won't lower (with load)!
On my 235, right in front of the seat is a "thumbwheel'. If that gets turned "clockwise" by repeated bumping of your foot when you're getting off the tractor, it will stop the 3 point from lowering. It actually controls how fast the 3 point drops.
ipz2222 is offline   Reply With Quote
Old 05-15-2010   #3
twomanyprojects
1st Yr. Apprentice
Equipment: L225
I should have mentioned that - I've tried it. It does act exactly like you had that valve in the locked position though.
Thanks
Frank
Old 05-15-2010   #4
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Could be air in the hyd system and its keeping it from going back down. Try and burb the hyd lines and see if you can get some air out of the system.
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 05-15-2010   #5
KubotaTech
2nd Yr. Apprentice
KubotaTech's Avatar
Equipment: None- I get to play with everyone elses stuff
If you crack the nut on that lowering speed valve, you can bleed out the air that may be trapped in the cylinder. Back it off slowly, it could possibly spray out fluid. After it goes down, try it again and see if it is any different.
KubotaTech is offline   Reply With Quote
Old 05-15-2010   #6
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
Do you have the backhoe hooked up right now or is it just lift arms with nothing on them?
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Old 05-15-2010   #7
twomanyprojects
1st Yr. Apprentice
Equipment: L225
It is fully loaded with the backhoe in mid-air. Lots of load to force the arms down.
I'll try bleeding the system.
Thanks
Frank
Old 05-16-2010   #8
pat331
3rd Yr. Apprentice
Equipment: L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Frank, do you have any quick disconnets? I failed to properly connect one on my L35 by not locking it in place. Everything would go one direction, but not the other. Connecting the quick disconnect properly solved my problem. Hope it is something simple.
pat331 is offline   Reply With Quote
Old 05-16-2010   #9
twomanyprojects
1st Yr. Apprentice
Equipment: L225
Thumbs up Problem Found! Re: Help -3-pt. hitch won't lower (with load)!
Eureka - I have found it!
The problem is in the fall speed adjuster under the seat - I had turned it many times to make sure it was open, but the valve is failing internally and was not opening. I turned it a whole lot more, and if finally opened and let the backhoe drop! Now I need to repair the fall speed adjuster valve, but at least that is easier to do.
I'm back in business, at least on that one. I'm still taking the front end loader off and taking the tractor to someone to check/replace the throw out bearing though, as I feel it is shot. (Plus I don't have the time and facilities to do it my self.)
Thanks for the help.
Frank
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
