Quandry???????????????
I have a 1978 Kubota L245DT. I have the original operators manual and the specification maintenance sheet too.
I have owned this tractor for 30 years and it has been a good one. HOWEVER, I just broke a rear axle and am in the process of fixing it. All done and ready to go back together.
THEN, I notice the spec sheet and manual shows that the transmission fluid recommendations are 80 WT GEAR OIL. Since this is where all the fluid comes for the tranny and rear end and loader and 3 point it just makes me wonder if this is not way toooooo heavy of oil. I have ALWAYS used transmission fluid. Seems to work just fine and there are a couple of very minor fluid drips occasionally but no big deal on that.
A friend that is a professional mechanic is helping me with this. He suggested that we use only 80 Wt. per specs in manual. Never using this before sure makes me wonder if stuff will still work. I bought a 5 gal pail of 80 wt but have not dumped in yet.
There is not a separate reservoir for the loader so it comes thru the system.
What is the correct answer? please help - quandry??????????
thanx
rrawhide
rrawhide@ocsnet.net
thanx
rrawhide
rrawhide@ocsnet.net
