you always speak of how easy this stuff is to do, and you are right,it was. I can cut a car in half and section in another half, but I hate going under the hood!Your Kubota will thank you for it all winter long!![]()
bearskinner,unsure about this procedure, but a quick and easy install. heres the part and freeze plug location. View attachment 13472
Pepsiboy, I picked mine up at the Kubota Dealer yesterday and with tax was just a few pennies under $89.
Dave,WOW ! ! !Kind of PRICEY isn't it ?? I think I'll get what is called a 'Tank Heater' 750 watts that recirculates the coolant around the engine for about $45 - $55 at O'Reilly's instead. Thanks.
Dave![]()
yes its a Kubota part, and it was $80.00. when I called the parts dept they quoted me $45, but that was for a small thread in one, not this one. It is a heavy duty unit. I plugged it in this morning for 1/2 an hour before starting the tractor. It was 18 degrees outside when I put my hand on the engine to see if it was warm, and it was HOT. I already feel good about adding it, the engine fired right up and idled smooth and no black smoke. If it cuts down on wear and tear, and helps keep it alive longer, that's $80 well spent.bearskinner,
Good job on the install.BTW, what was the cost of the frost plug heater ? Was it from Kubota ? I've been thinking about that for my BX2350 also.
Dave
Wolfman,Dave,
$89 is not that spendy for a purpose built heater, you can get them for cheaper off EBay, just have to wait for shipping.
Look real carefully before jumping into a Tank type heater as most require that you hook up to a heater (3/4", 5/8") hose and I'm betting you don't have that on your Kubota!![]()
