Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Tractor Operating
Tractor Operating Wondering what that strange lever does, how to safely hill climb or get into 4WD? Discover and share how to get the most out of your tractor.
Reply
Thread Tools Display Modes
Old 03-24-2010   #1
pat331
3rd Yr. Apprentice
Equipment: L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Default Draw Bar II w/ Winch
For those of you who wondered how I hooked up my winch to the drawbar, here are pictures of my setup. I bolted the winch to a hitch receiver portable winch mount, mounted the battery to temporary platform bolted to the drawbar, ran a charging wire from the starter to the + side of the battery, hooked a ground wire from the - pole to the tractor body, hooked the + & - winch cables to the battery, and was in business. Yes, I have a snatch block, but the tree I was snaking out was not that heavy and I needed as much line as I could get getting the log out of the bushes. I'd probably snaked out 25 logs or so before the last one hit a stump just right. I've since repaired the winch. As shown in the picture with the double line, the winch has enough power to move the L35 even with the bucket down. Got the winch from a good buddy that didn't need it anymore. Don't use it very often, but when I do, it is HANDY!
Click image for larger version
ID:	1282   Click image for larger version
ID:	1283   Click image for larger version
ID:	1284   Click image for larger version
pat331 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-24-2010   #2
dusty-t
4th Yr. Apprentice
dusty-t's Avatar
Default Re: Draw Bar II w/ Winch
He must have been a GOOD buddy thats a nice winch.I still love that quick hitch. Soon, soon I hope to make one of these. Thanks for the pics Dusty
dusty-t is offline   Reply With Quote
Old 03-24-2010   #3
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Here's a suggestion to power that winch without the need of an extra battery to power it. Purchase a polarized socket and mount that on the tractor and connect it to the tractor battery and then get yourself a lexan plug to put on the end of the cables of the winch and you have a handy way to power and run the winch without the need on an extra battery.
http://www.awdirect.com/polarized-so...s-accessories/
http://www.awdirect.com/replacement-...s-accessories/
Yeah its kinda pricey but its well worth it, My dad and I have the same polarized socket and jumper cables on our trucks which make it nice not having to pop open the hood of your truck to jumpstart things.
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 03-24-2010   #4
Eric McCarthy
VIP Service Tech
Also one or two of these scotch block bad boys will help hold the tractor in place and not tear up your tractor parking break nor the FEL. when winching anything.
http://www.awdirect.com/steel-scotch...scotch-blocks/
__________________
Old 03-24-2010   #5
pat331
3rd Yr. Apprentice
Thanks the compliments and advice. I really like the quick plugs for jumper cables. I'd love to have several of them. What I used was taken from the junk that I had on hand, including the battery, robbed from the travel trailer. Thanks again.
Old 03-24-2010   #6
Eric McCarthy
VIP Service Tech
Yes sir
I thought maybe you could use the ideas on the quick plug to make life simple and make the entire project neat and clean and eliminate some extra junky wires since you have a sharp looking setup already
__________________
Old 03-24-2010   #7
traildust
Journeyman
traildust's Avatar
Equipment: B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Eric, those polarized sockets are a good idea. On ptwyz's lawn mower towing device it looked like he had that connector.
Man them chalks are expensive at $219.99
Scott
__________________
Scott
AW LAWDY here we go with more technical mombojombo! - Eric McCarthy
traildust is offline   Reply With Quote
Old 03-24-2010   #8
traildust
Journeyman
traildust's Avatar
Patt,
Thanks for taking the time to post such great details! Those pic's were great, thank you.
Scott
__________________
Scott
Old 03-24-2010   #9
Eric McCarthy
VIP Service Tech
Yeah the scotch blocks are a little steep but man they have saved my ass from sliding into a ditch when recovering a car on more then one occasion and are worth their weight in gold to me.
__________________
Old 03-24-2010   #10
traildust
Journeyman
traildust's Avatar
Quote:
Well I hear ya there! In that case those blocks are priceless!!
Scott
__________________
Scott
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
