Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Tires & Wheels
Tires & Wheels Discuss everything related to ag, turf or industrial tires, wheels, rims, ballast and chains right here.
Reply
Thread Tools Display Modes
Old 03-19-2010   #1
tiger9297
1st Yr. Apprentice
Equipment: B7100HST-D w/ Bush Hog FEL
Default Ag tires not available????? Help please.
I have a Kubota B7100HST 4x4. Right now the tractor has turf tires on the rear and basically "slicks" on the front. No, they are not worn out, but literally have no tread. Not sure what you would call them. Anyway, the front tires are 20.5x8-10. I have put a loader on this tractor, and wanted more aggressive tires. My plan was to put industrial tires on it, but they aren't available in these sizes, so I figured I just go with some "old school" ags. Well, they aren't available in the size I need for the front tires. I can't believe that ag tires are not available for the front of a 4-wheel-drive tractor. Does anyone have any suggestions???
Click image for larger version
tiger9297 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-19-2010   #2
Randyj
2nd Yr. Apprentice
Randyj's Avatar
Equipment: B9200D / BF350 Kubota Loader / L-4530B Kubota Backhoe w - subframe / LP GS1548
Default Re: Ag tires not available????? Help please.
With 4X4 you have to make sure you have the correct sized tire & wheel. Look at your owners manual to make sure of this. Then, I would think that "Titan" would have the correct tire for your rig.
Randyj is offline   Reply With Quote
Old 03-19-2010   #3
Captjack
1st Yr. Apprentice
What I would do
is go to Firestones website(because its a good site) and get the OD (OVERALL DIAMETER) specs on your current tires. Then go to the ag section and find tires that are close to that size in OD and width.
Keep in mind if you go a little bit bigger on the rear - you have to find a front tire that is the same difference from the stock front tire - in other words if you go an inch bigger than stock on the rear you will need to go an inch bigger on the front.
Should be easy to do - pm me if you need help and I can assist - spent 20 years of my life in the tire biz
Captjack is offline   Reply With Quote
Old 03-19-2010   #4
L4740
2nd Yr. Apprentice
This is a common discussion here. Search "tires" or "tyres" and you will find many post regarding this subject. As others have already mentioned it is very important to keep the rolling circumference ratio the same as the old tires. The problem is that ag tires (A1's) will not fit on a 10" wide rim. You will also need to replace your front rims to accommodate the ag tires. Usually a 4 or 5" rim is what they will require. Industrial tires (R4's) will fit a 10" rim, but you may not be able to find them with the proper diameter to suit your needs. In most cases, when switching from turfs to ags, it is necessary to also change your rims. Good luck
L4740 is offline   Reply With Quote
Old 03-19-2010   #5
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Dumb question but what can happen or what damage can be done if you DON'T keep the same rolling size tires all the way around like Jack warned us about? He has mentioned if you go an inch bigger on the rear do the same for the front. Or does that just apply to 4x4's because of the front axle having torque placed on it when the 4x4 is engaged.
__________________
West End Lawn & Garden
Eric McCarthy is offline   Reply With Quote
Old 03-20-2010   #6
B7100
3rd Yr. Apprentice
Equipment: B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Quote:
There is a formular for working it out but when I bought my new Ags the dealer did it for me
Wind up happens when in 4 wheel drive, because there is no diff in the transfer box, so when cornering on tarmac or other hard road surfaces, the front axle takes a slightly larger turning circle than the back, so the front axle turns a few more times than the rear axle, therefore the rear output shaft will want to turn slightly slower than the front output shaft. Now as the front and rear output shafts are locked together, only one thing can happen, the shaft will try and twist, hence the name wind up. It may not be noticeable on soft ground or snow as a wheel may slip and relase the wind up.I have seen an accident when an inexperienced chap tried to undo the uj nuts after a wind up without jacking up a wheel to relase the tension and nearly lost his finger.
dave
B7100 is offline   Reply With Quote
Old 03-20-2010   #7
Service Dept Vic
Service Dept Vic's Avatar
Titan (Goodyear) and Firestone/Bridgestone have 20 x8x10 Industrials available, but not that 20.5x8x10 that was OE on the front of your Kubota.
That 20.5 size disapperaed long ago! Some tent trailers still use that size and there is good inventory for folks making use of a smooth or sawtooth tread pattern up front to replace their worn out turfs.
I'd be inclined to try the Titans R3's, and keep the air pressure up in the tires to compensate for the slightly smaller rolling circumferance, or at the very least, measure your old ones and compare to the new Titans. You may find that they are very close regardless.
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 03-20-2010   #8
Eric McCarthy
VIP Service Tech
WOW never knew or thought of tire size causing that much of a problem. That's amazing.
__________________
Old 03-20-2010   #9
traildust
Journeyman
traildust's Avatar
Equipment: B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
No kidding! Never thought about this either
Quote:
Originally Posted by B7100 View Post
...I have seen an accident when an inexperienced chap tried to undo the uj nuts after a wind up without jacking up a wheel to relase the tension and nearly lost his finger...
Scott
__________________
Scott
AW LAWDY here we go with more technical mombojombo! - Eric McCarthy
traildust is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
