B5200 flasher trouble
R0ckl0bster
B5200
Dec 14, 2009
Becker, MN
Hey all, new to the orange brotherhood and think I'll need some expert advise.
Just picked up my first Kubota.1986 B5200, 4x4, FEL, 3 point mower, chains and a trailer to tote it around on. Has 500 hours and all works great except for the flashers. Just wondering where I should start trouble shooting and if I need to pull the dash off before I start......?I do have a copy of the wiring diagram.
Thanks
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
Thanks
Sorry guys, I don't know abything about the flashers. Does sound strange though. Ok, I'll take a stab. Switch unit and or a flashing timer/relay if it has one.
Mostly saying welcome to R0ckl0bster for joining the forums.
Your post sounds like you got a hell of a deal with all that stuff and a trailer too :eek:
Scott
phildac
1984 B8200E, L260F
Jul 29, 2009
203
Wentzville, MO
Not sure about the B5200, but I replaced the Kubota flasher unit on my friends B8200E with a $3 two terminal 552 flasher from NAPA. Beats paying $47.75 plus S&H for the Kubota FLASHER UNIT 35170-33700. By twisting the two terminals 45 degrees, you can plug it into the factory 4 terminal harness plug. So I didn't have to cut the factory wiring. Three wires White/Red- fused 12v from key switch , Black- ground which I didn't use, Red/Yellow- input lead to hazzard switch. Fourth spot is empty. Works like a charm.:D
Hope this helps Green Mountain Slim.
traildust
Jan 27, 2010
1,490
Phelan, California
Thanks for posting that tip! A savings of $44.75 :eek:
Scott
R0ckl0bster
B5200
Dec 14, 2009
Becker, MN
Thanks for all the helpful tips. After checking the bulbs I got to studying the wiring diagram. Found out the B5200 has a dedicated 5amp fuse for the flasher circuit. Turns out that was blown. Sorry for the false alarm about the service issue as I overlooked the obvious. Hey, I found the B5200 is prewired for a aux work lamp on the back so that will be my first addition...Thanks again everyone.
traildust
Jan 27, 2010
1,490
Phelan, California
Congratulations! .
Now sweat, everybody overlooks the symple stuff.
Scott
