Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Fabrication & Customization
Fabrication & Customization Show off and share the details of your custom improvements to your tractor, your truck or anything else you get your hands on.
Reply
Thread Tools Display Modes
Old 10-17-2013   #1
Cheapsnake
New Member
Equipment: GT1800
Default Cab heater via reversed radiator fan
I just finished fabbing up a cab for a GT1800 and now I'm looking to get some heat into it. The radiator fan pulls air from under the dash through the radiator. I'm thinking a really elegant way to get heat into the cab would be to simply reverse the air flow so the fan blows through the radiator INTO the cab instead of sucking air out of it. Ideally, I would simply reverse the fan blade, but reversing it doesn't reverse the flow, believe it or not. The only thing that would reverse the flow on a stock fan would be to reverse the rotation. Not going to happen.
Sooooo, the next best thing I'm thinking is to fabricate a new blade out of aluminum with the blades oriented to blow through the radiator. Has anybody had anybody had any experience with this?
Lacking that, I'm interested in any cab heater designs. Thanks.
Tom
Cheapsnake is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-17-2013   #2
lsmurphy
Journeyman
lsmurphy's Avatar
Equipment: B7001
Default Re: Cab heater via reversed radiator fan
Fans are pushers or pullers.
You have a pusher........find a puller.
No, you don't need to build one.
lsmurphy is offline   Reply With Quote
Old 10-18-2013   #3
VIP Service Tech
skeets's Avatar
Equipment: BX 2360
I really don't know how much time your going to be spending in yoru cab but you might be surprised how much heat your body will give off enclosed and if the sun is shinning that will heat you up as well,, of you could tap into your rad lines and put a small core in the cab with a fan,,, but I would think having the engine fan blowing in the cab would become a bit uncomfortable after a while don't for get you cant control the air flow unless you control the motor speed
skeets is offline   Reply With Quote
Old 10-18-2013   #4
Cheapsnake
New Member
Equipment: GT1800
Excellent! Is this a Kubota item or do I have to adapt one from another application?
Skeets, a big reason for heat (circulation) in the cab is to keep the windows from frosting up, cuz along with heat, your body is throwing off a lot of moisture which turns to ice as soon as it hits the glass.
Old 10-18-2013   #5
Jmsossi
New Member
Equipment: Gr2120 snowblowing mowing
Hi
You could remove the fan blade from your engine then install a electric fan like they use on automotive radiators to pull the air into the cab. Or another option would be to install a aux heater in the cab. That is the way I did it on my gr2120 I get lots of heat and it only takes about 5 min to come up to temp.
Joe
Jmsossi is offline   Reply With Quote
Old 10-18-2013   #6
Cheapsnake
New Member
Equipment: GT1800
Quote:
Originally Posted by Jmsossi View Post
Hi
Joe
Excellent idea with the electric fan. It does appear to be enough room to install a small one as long as the alternator can keep up with it. My fallback would be to install a heater in the cab if the fan thing doesn't work out, but that radiator heater looks so made-to-order I've got to play it out.
BTW, that is one fine looking piece of work you did on your cab. Almost makes you wish for snow...OK, maybe not.
Old 10-19-2013   #7
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
Food for thought!
Reversing the fan might seem like simple solution, but make sure you pay your medical and life insurance policies, one little exhaust leak or enough front exhaust flow and you'll be drooling all the time or pushing up daises!
This is the simple reason they don't normally use radiant engine or radiator heat to heat the cab!
I"ll even go as far as to mention what could happen if you had an engine or under the hood fire, it wouldn't be a fun back yard barbeque!
North Idaho Wolfman is offline   Reply With Quote
Old 10-19-2013   #8
Cheapsnake
New Member
Equipment: GT1800
Good point Wolfman.
Old 10-19-2013   #9
jb62901
2nd Yr. Apprentice
jb62901's Avatar
I installed a heater core i had, put a 4" DC fan behind it. Click image for larger version
Name:	by pass hose.jpg
__________________
BX2360 LA243 FEL + Tons of Implements Many Homemade.
jb62901 is offline   Reply With Quote
Old 10-19-2013   #10
jb62901
2nd Yr. Apprentice
jb62901's Avatar
Heater core Click image for larger version
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
