Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 09-05-2013   #1
boomer128
New Member
Equipment: B7510
Default loader bucket won't lower
I just bought a used B7510 HST with a Woods joystick bucket. The bucket will go up and rotate up and down but the bucket will not lower. Ideas please?
boomer128 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-05-2013   #2
helomech
4th Yr. Apprentice
Default Re: loader bucket won't lower
Lower your 3 point hitch a little and try that. If the 3 point is too high then it will mess with the loader, took me months to figure that out. Kubota must not have set the upper stop right on my tractor.
helomech is offline   Reply With Quote
Old 09-06-2013   #3
alchemysa
1st Yr. Apprentice
Equipment: B1550, backhoe, 4in1 bucket, rear mower.
Check that the return hydraulic coupling is correctly attached. (Be careful - it may be under pressure.) I think in the 'float' position it should at least lower by gravity alone if the couplings are attached correctly.
'Float' is when you push the joystick ALL the way up. It releases all pressure from the hoses. (Assuming you have float). If it doesn't drop in the float position then the coupling may not be correctly attached.
alchemysa is offline   Reply With Quote
Old 09-06-2013   #4
Chubbs75
1st Yr. Apprentice
Default
Could be faulty quick release coupling but also hydraulic ram. Eliminate problems starting from lifting cylinder. Loosen up hoses on cylinder to see if oil comes out and if bucket drops. Swop couplings if necessary.
If those 2 ok then you might have a faulty control valve block.
Chubbs75 is offline   Reply With Quote
Old 09-07-2013   #5
boomer128
New Member
Equipment: B7510
Quote:
thanks, I will give it a try.
Old 09-07-2013   #6
boomer128
New Member
Equipment: B7510
thanks. I will check those
Old 09-07-2013   #7
boomer128
New Member
Equipment: B7510
thanks, I will check that
Old 09-14-2017   #8
mblossom
Equipment: B7500
My B7500 LA272 loader wouldn't lower this morning, I read posts here, went back out and tried it again without making any changes, it works fine now. See, reading this forum fixes things!
There is a hard detent at the top of the travel of the stick, which I hadn't noticed before, and which I thought at first was the cause of the FEL not lowering. Is this a stuck ball or other fault, or is it the detent for the FLOAT position, which I have never fully understood anyway?
mblossom is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
