Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 01-26-2010   #1
brady-yzf
New Member
Equipment: L35, BT900
Default Hydraulic Whine-L35
I'm getting a hydraulic whine and it feels like the pump is laboring in my 2001 L35 whenever I am not moving my loader bucket either up and down or rotationally. The fluid and filter is brand new and all other hydraulics are disconnnected.
Here is the chronology:
I first heard the whine when operating my BT900 backhoe, I noticed at the same time that my dipperstick started extending very slowly. It still contracted at the normal rate with the normal force, but the extension was slow and weak. I dissassembled the valve assembly, inspected and cleaned it and put it back on. That was not the problem. I was advised to replace the seals in the dipperstick piston; those parts are on order but I'm not sure that that's the problem.
I removed the backhoe so I could still use the loader and I'm still getting the whine and the "feel" that the pump is struggling when the engine is running. The whine goes away when I'm moving the loader. Should I check the loader valves? ANy input would be very helpful, thanks!
brady-yzf is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-28-2010   #2
ipz2222
Journeyman
Equipment: L235, bx2670
Default Re: Hydraulic Whine-L35
Im not familiar with your tractor but,, a hydralic whine is caused by 3 things. Restriction on intake side, pump trying to mantain max pressure and pump vanes or rotor scarred and rubbing. Either 1 of these or all together.
ipz2222 is offline   Reply With Quote
Old 01-29-2010   #3
pat331
3rd Yr. Apprentice
Equipment: L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Brady-yzf
I had a similar experience with my L35. Turned out I did not have one of the rear hoses from the backhoe completey inserted together. Properly inserting the hoses together cured my problem. Hope this is simple fix for you.
pat331 is offline   Reply With Quote
Old 02-03-2010   #4
brady-yzf
New Member
Well, I can tell you what it's NOT. I dissassembled both the backhoe and the loader valve assemblies as well as replaced the seals in some of the hydraulic pistons that weren't working properly. I dissassembled and inspected all the quick connects to make sure none were obstructed.
Perhaps I'm not adequately describing the symptom: It's not really a loud, high-pitched whine, but more of a slightly audible noise when the machine is in neutral hydraulic position. It's a noise that sounds like the pump is under load. I'm hypothesizing that the problem could be with a stuck relief valve. I think this because the noise goes away while an attachment (either loader or backhoe) is moving. Do relief valves commonly get stuck?
THe other thing is that the noise is not that bad, but I've never noticed it before. I don't want to fix something that isn't broken.
Thanks,
Brady
Old 02-04-2010   #5
Service Dept Vic
Service Dept Vic's Avatar
Disconnect the main pump "in" line, the one that goes right into the top of the hydraulic pump and see if you have a piece of foil or flashing right at that point restricting the pumps intake.
The tractors relief valve may have a piece of crap in in as well, causing the operating system to operate at a much lower pressure, clean and check.
Also take a look at the relief valve cartridge on the loader control.
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 02-07-2010   #6
brady-yzf
New Member
Default Fixed! thanks Vic
I dont' exactly know where the little piece of crap was, but I cleaned the pump and the relief valve, and now she's fixed and ready for more abuse! Thanks for the help-
Brady
Old 05-09-2011   #7
wakokaila
Hi,
I have several heavy equipment under my section and experience a similar problem with one of my graders. The hydraulic pump whines when the machine is on Neutral and the sound goes out when the machine is put on gears. Do you think it would be a similar solution as to what you are discussing here? Thanx..
wakokaila is offline   Reply With Quote
Reply
Tags
hydraulic, l35, pump, valves, whine
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
