Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Tractor Operating
Tractor Operating Wondering what that strange lever does, how to safely hill climb or get into 4WD? Discover and share how to get the most out of your tractor.
Reply
Thread Tools Display Modes
Old 06-11-2013   #1
78-79fordman
2nd Yr. Apprentice
78-79fordman's Avatar
Equipment: 2013 m7040hd 2013 L3800HST 1969 MF135
Default Bush hog speed .
Ok have no clue were to run this m7040 . Done some to day . So look at pics and see it it looks right . It's a 1870 landpride .
There's two pics of the gauges . Do I need the pto speed at or around 540 . Or what I was in second low gear hard it sat at 540 or so for 3rd low gear .
So am I any were close to right .
Sent from my iPhone 5 using Tapatalk 2
78-79fordman is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-12-2013   #2
Bulldog
Master Tech
Bulldog's Avatar
Equipment: M 9000 DTC, L 3000 DT
Default Re: Bush hog speed .
The pto should be at 540 rpm's and your ground speed is whatever is comfortable for you. No matter what the ground speed is the cutter is designed to be operated at 540.
__________________
AMSOIL, protect your investment.
Bulldog is offline   Reply With Quote
Old 06-13-2013   #3
Bluegill
Journeyman
Equipment: L3750DT Shuttle, L3800DT FEL both
Just do what works best for your conditions. I never run at full rpm.
Bluegill is offline   Reply With Quote
Old 06-13-2013   #4
Tx Jim
4th Yr. Apprentice
Equipment: M7040 HDC-1
78-79fordman
Bottom number on tach in the bottom photo of your post is pto speed. Most implements were built to built to run a 540.
Tx Jim is offline   Reply With Quote
Old 06-13-2013   #5
MagKarl
4th Yr. Apprentice
Equipment: L245DT
I figure 540 for really hard cutting, pretty much whatever you think is the worst the unit is designed for. For cutting grass and light brush, I run more like 2000rpm engine speed, where my 540 mark is about 2800 engine rpm. As long as it's cutting cleanly, the blade speed is fast enough for me. Just my opinion anyway.
__________________
L245DT with 1200 FEL, 4520B backhoe on subframe, 5' brush mower, 5' box blade, bucket forks, Unicorn splitter, 6' 6 way blade, PTO chipper
MagKarl is offline   Reply With Quote
Old 06-15-2013   #6
Saxman
1st Yr. Apprentice
Equipment: L3830 ZD21
Default
Unless conditions require it I run my L3830 at about 2200 RPM, that makes the PTO speed less than 540 but it still does a good job mowing and the engine is not screaming unnecessarily
Saxman is offline   Reply With Quote
Old 06-16-2013   #7
bransdad
New Member
When I bush hog I run a 10ft. offset bush hog. I pull it with a M6800. In tall grass I run it around 2000 rpm in Low 3rd. In shorter grass I run it in low 4th around 1800-2000 rpm. Very seldom do I run the PTO at 540 rpm.
bransdad is offline   Reply With Quote
Old 06-17-2013   #8
WFM
3rd Yr. Apprentice
WFM's Avatar
Equipment: L3800
So If your just mowing grass or brush, 540 rpm's is not necessary ??
WFM is offline   Reply With Quote
Old 06-17-2013   #9
Bluegill
Journeyman
Quote:
540 is max rpm, doesn't hurt a thing to run them below that. I've been doing it for 30 years.
Old 06-17-2013   #10
bransdad
New Member
No you don't have to run it at 540. I actually try to stay off of 540 if I can. I was able to mow some grass today in high 1st with the motor rpm running in the range of 2000-2200. At 2200 rpm I was running 530 on the PTO.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
