Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Tractor Operating
Tractor Operating Wondering what that strange lever does, how to safely hill climb or get into 4WD? Discover and share how to get the most out of your tractor.
Reply
Thread Tools Display Modes
Old 05-27-2013   #1
mlindyq
Equipment: BX 2360
Default BX2360 won't shut off.
While cutting grass, a bump was hit causing the seat safety switch wires to be cut in half (poor layout of wires.) Of course the motor stopped. I rerouted and spliced the wires and continued cutting. When I was done I went to shut down and it wouldn't shut off. Parked the machine and stalled it out. Currently, I cut and when finished, push the stop solenoid lever in. Are all these wires interconnectted? Is there a fuse panel ? I just seems odd 2 things going wrong at the same time. Any help would be appreciated.
mlindyq is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-27-2013   #2
kc8fbl
2nd Yr. Apprentice
kc8fbl's Avatar
Equipment: 2014 L3200 HST FEL, 1949 Minneapolis-Moline R
Send a message via Yahoo to kc8fbl
Default Re: BX2360 won't shut off.
I think there may be a fuse to shut it off. There is another post on another tractor not shutting off. Check your fuses.
__________________
Greg
kc8fbl is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
