yardtoy1
kubota3010, case580SE,zator 3320, komatsu 53-17 track loader, deer70 escavator,
I have a L3010 I changed the trans/ hydrolic oil and added2 lines to the rear of the tractor 1 pressure and 1 to the holding tank for a post driver, the tractor sat for a couple days with out hydro fluid, when I filled the reservoir the loader would work fine but not the 3 point. did I create a air lockin the 3 point, is there a bolt or vent to purge the system. also do you think it would be possible to use the fill point at the top of the differential as a hydrolic dump location for this shaver post driver
