I have been having trouble with the neutral safety starting switch on the forward/reverse lever. And I want to adjust or replace it.
My problem is that I can not get the throttle lever off of the rod that controls the throttle. This lever has to be removed before the plastic cover over the switch area can be removed.
I took the pin out of the lever and rod and expected the lever to come off.
But no. It seems to be pressed on. Could that be or is it just rusted? Will heat loosen it or do I have to get a puller to take the lever off? There is not much room for a puller. I do not want to destroy the plastic cover in the process.
How should I proceed.
Thank you. bob
Thank you. bob
