Hi. I've got a couple of issues with my old kubota.
The first thing is I'm getting oil dripping from the rear axle / hubs. I haven't looked to see the problem yet but could anyone tell me do these tractors have oil in the hubs? Or should they be dry when I take them apart? I assume if the hubs should be dry the oil is leaking from a seal that the drive shaft goes through, is this correct? Also are the brakes housed in there? Or are they in the actual axle?
I can't seem to upload a photo but hope you understand what I mean?
The other issue is wiv the rear link arms. I've just bought a topper (mower) to go on the 3pt linkage. When I raise the mower up the front of the mower touches the rear tyres. Do different models have different length lift arms? I would like to have at least 2" / 3" clearance between the implement & the tyres. My thoughts are either find some longer arms or a last resort would be cutting them & welding them up a bit longer. I'm unsure of doing this as the tractor needs to be strong enough not be bend or flex.
Obviously if I have longer arms will make implements heavier than if they shorter with the weight closer to the tractor.
Please help lads
Please help lads
