Figured i'd start a new thread with just this issue and use to to brainstorm or add how it was fixed.
drive shaft (from rear transmission output to front axle) has crappy u-joints and the rear yoke has female splines that are rusted away.
Front side is the long yoke and slips on input shaft, but shorter rear yoke is splines and a roll pin to hold it in place. Well, the rear output shaft looks to have some wear but mostly the drive shaft yoke female splines probably held water and rusted away.
What i've found so far is that it's 18t and 25mm wide, the yoke is no longer available but the whole driveshaft is (over $400)
Options: machine shop make new end?
source female splined tube to weld onto old yoke?
buy new drive shaft?
I've found a few listings for slip spline couplers from kubota and am going to auto store to compare u-joints to a few foreign auto parts.
