New to the crowd. G5200
Walker111
G5200
Sep 7, 2018
Fburg VA
Update....picked up a few more Kubotas
Just picked up a G5200 the other day with 765 hours and in great shape. In the process of doing all the routine maintenance plus rust preventative and repainting the deck. Looking forward to learning more about these machines.
4,389
But wait a minute, the engine is in there backwards!:D
Welcome, but be careful diesel powered things become addictive.
2,815
Oh my he is just starting,,, sit down and breath deeply close your eyes,,, relax and say diesel is bad,,, diesel is not good,,, diesel in addictive,,, diesel is expensive..... Well OK that didnt work for any of us either ,,, Enjoy the little beasty :D
Walker111
G5200
Sep 7, 2018
Fburg VA
Got some stuff done today...
Oil and filter
UDT2, filter, and bolt screen thing
Drained fuel, replaced both filters
Coolant, thermostat, and overflow bottle
Greased everything
Cleaned everything
Removed deck, cleaned, ospho’d, POR15’d, sprayed orange.
Added some wheel weights
Everything is back together minus the deck, still waiting for paint to dry.
4,389
Nice detail work. If you ospho’d it how did you get painted already? Need to give it a day to dry, don't you?
Walker111
G5200
Sep 7, 2018
Fburg VA
Anyone know the frame color? Kubota blue? or Dark Grey Enamel?
Also, how do I find out what year this thing is? Serial number on the frame is 38122. Serial number on the engine is 118151.
TIA
Walker111
G5200
Sep 7, 2018
Fburg VA
Used the tractor yesterday after all the maintenance, ran like a top. What a difference in my yard the wheel weights made, I barely had any slip. Coolant needle never made it more than a third of the way. Friggin love this thing.
Walker111
G5200
Sep 7, 2018
Fburg VA
Made some deck adjustments yesterday. Noticed the deck I have is a RC48-G20. It’s kind of a pain in the ass because there aren’t any turnbuckles, so you have to disconnect each arm for every adjustment.
I like to keep my grass tall, so the couple of times I’ve mowed, I’ve left the deck raised. The driveline angle is fine and doesn’t come into contact with anything. I was able to get it pretty even, hopefully, when this monsoon is over I can test it out.
Also put another coat of metal protector on the deck.
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
240
Southern IL
The manual for the deck has some specific measurements for length of those buckles. Makes deck spot-on level.
cliffboyer
Nov 30, 2017
240
Southern IL
Wait...I just noticed your deck pto points to the rear?
That's different from my G5200. Where does your pto power come from?
