grill guard
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
next project for my B2620!
While pushing back some brush along a fence line today a broken piece of sapling came thru the slats in my stock grill guard . The grill will be ok after some heat gun work and the battery saved the radiator and also survived.
So will be adding some wings to the existing guard and some expanded steel mesh.
Pictures of anyone's like minded mod would be appreciated.
alansz400
B7500. FEL, Piranha tooth bar, box scraper, post hole digger, 3 pt. bucket
Oct 26, 2013
265
Loudonville OHIO
I bolted some angle iron on and welded the expanded metal to it. Did not have to drill any new holes.
5,051
Does that tractor belongs to the military? :eek:
Bomb removal team? ;)
Seriously nice job!
m32825
L3800HST
Jul 12, 2013
204
10
Central FL
Alansz40 nice work! How do you fuel it up, isn't the cap under the guard?
-- Carl
bandaidmd
May 19, 2013
603
Middle of DELMARVA
Decided to not add the wings since theres ony a couple inches on either side. Put one extra crossbar at the bottom and some mesh.
Its sitting in the blast cabinet ready for clean up and paint.
Sent from my SCH-I605 using Tapatalk
alansz400
Oct 26, 2013
265
Loudonville OHIO
-- Carl
It flips forward and lays straight out the front. I can pull one pin out and the whole thing lifts off.
994
Look for perforated steel
I think you will find all types
SRS
Cabbed B3030, equipped with a FEL, FEL snow plow, belly mower, and forks.
Jan 3, 2010
Jarrettsville, Maryland
Here's how I made mine for a B3030. Getting the angles correct was the toughest. I had scraps of the screening and used several pieces and welded them together to make one full screen. I have a 2" receiver mounted on the front of the tractor where I can attach/detach this brush guard from the tractor as I only need it when I'm using my grappler. I apologize for the sideway pictures.
