B Bigscooter New member Equipment B6000 Oct 21, 2018 16 2 3 Southern Oregon Oct 26, 2018 #1 Want to buy B6000 Lift arms. left lift arm 66591-36733 right lIft arm 66591-36743 thanks!
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,306 4,856 113 Sandpoint, ID Oct 26, 2018 #2 Check out these: https://www.ebay.com/itm/Kubota-B51...575531?hash=item33f6e59e6b:g:vSQAAOSwOkxbv5At https://www.ebay.com/itm/Kubota-B6000-Fuel-Tank/223202536201?hash=item33f7e86b09:g:Th0AAOSwJmVb0Lrh
B Bigscooter New member Equipment B6000 Oct 21, 2018 16 2 3 Southern Oregon Oct 26, 2018 #3 North Idaho Wolfman said: Check out these: https://www.ebay.com/itm/Kubota-B51...575531?hash=item33f6e59e6b:g:vSQAAOSwOkxbv5At https://www.ebay.com/itm/Kubota-B6000-Fuel-Tank/223202536201?hash=item33f7e86b09:g:Th0AAOSwJmVb0Lrh Click to expand... Wow that's the whole set up. I will definitely need all of that stuff. Now if I could only find this splined ones That come out under the seat.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,306 4,856 113 Sandpoint, ID Oct 26, 2018 #4 This is the whole set up. https://www.ebay.com/itm/Kubota-B60...=item4b529bf043:g:KwsAAOSwoM5bywNv:rk:36:pf:0
D D2Cat Well-known member Lifetime Member Equipment L305DT, B7100HST, TG1860, TG1860D, L4240 Mar 27, 2014 12,901 4,269 113 40 miles south of Kansas City Oct 27, 2018 #5 Yep, and all those items are by the same seller. So he may have other items you may need.
B Bigscooter New member Equipment B6000 Oct 21, 2018 16 2 3 Southern Oregon Oct 27, 2018 #6 North Idaho Wolfman said: This is the whole set up. https://www.ebay.com/itm/Kubota-B60...=item4b529bf043:g:KwsAAOSwoM5bywNv:rk:36:pf:0 Click to expand... yes it is! thanks!
