Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 07-12-2016   #1
MikeinDewey
New Member
Equipment: L39 TLB
Default L39TLB Auto-Shifting Transmission
The GST transmission on my L39 suddenly started to auto-shift; that is, when placed in most any gear it suddenly decides to rapidly bounce around to plus or minus the selected gear, displaying the gear changes on the display panel and confusing the drivetrain (and the driver). Is there an intelligent path for troubleshooting this problem or knowing guesses as to the obvious cause? The tractor has just over 800 hours and the transmission fluid and filters were replaced roughly 30 hours ago. All other hydraulics work just fine. Previously, 1st and second gear would occasionally disappear but 3rd seemed to have become 1st, but the cause (hot or cold, forward or reverse, 2WD or 4WD) was not consistent and I simply worked around the annoyance. This escalation of what I assume to be part of the same problem is a little harder to ignore.
MikeinDewey is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-16-2016   #2
MikeinDewey
New Member
Equipment: L39 TLB
Default Re: L39TLB Auto-Shifting Transmission
I took out the GST Lever Sensor and found some corrosion on the electrical pins. Also, the cable connector seemed to be loose. After cleaning the pins and using some electrical tape to secure the connector to the Sensor, the auto-shifting seems to have been cured. Occasionally loosing 1st and 2nd gear, with 3rd seemingly becoming 1st (or 2nd) is still an issue, for another day. Also, I don't often use gears 7-12, but just noticed that when I do, there's a pause and then a kick into gear that makes me think that I should be wearing chaps and a cowboy hat. If anyone happens to have an idea for dealing with either of those two issues, it'd be appreciated. I did go through the WSM and found squat and also went through the Electronic Instrument Panel diagnostics and found all the settings to be nominal with no stored error codes.
Reply
Tags
gst, l39, shift, transmission
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
