Bx2370 3 point bleeds off while running
windzer
Bx2370-1
Dec 8, 2015
82
Illinois usa
I got a quick question for you guys does anybody elses bx 2370 3 point bleeds off while the engine is running of course I have my 50 inch tiller on there and it seems to drop 3 or 4 inches or so in a half hour while I'm running around using the loader.is that normal or should I be calling up the dealer cause it only has 25 hours on it. Thanks I appreciate any info guys.
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
I don't know for sure but doesn't sound right to me. How is your drop rate adjustment set? Maybe adjust that and see if it makes a difference.
brimar
bx 1870 48" mmm fel
Oct 5, 2014
21
lancaster PA
I just got my BX1870 back from the dealer at 170 hrs I had a drop rate of 4.5 minutes for full travel of the arms with 30 # on. There was no question about warranty on that . seal was tore and cyl was scored . For your hours check with dealer I am unsure about acceptable drop.
TripleR
Sep 16, 2011
1,911
38
SE Missouri
Nature of the beast if it is not position control, no BX has position control; lots of different threads on this.
