L2250 RPM stuck and Hours not tracking
gsayler
L2250DT
Jul 22, 2016
Beulah, North Dakota
Purchased this little bad boy several months ago. The man mentioned that the hours were not working but was not sure how to fix the issue. Also a couple weeks ago the RPM's stopped reading. Any advice how to fix either of my issues?
whitetiger
Nov 20, 2011
2,542
1,059
Kansas City, KS
The Tachometer with hour-meter assemble is available for that unit rather than replace the entire dash. Check your Tachometer cable also, I replace it when replacing Tach.
mendonsy
B7500HST/LA302
May 28, 2012
339
19
Mendon, NY
The first thing to check is the cable. A broken tach cable is a very common failure.
You can check it by disconnecting both ends and turning the inner cable by hand to make sure it isn't broken.
