Thoughts on what's best....a Pirahna bar or a Tooth bar for my FEL? It will be used in pretty rocky ground probably 75% of the time. Thanks!
I am assuming that you are referring to a toothbar that has long teeth on it as an industrial tooth bar? Much like a backhoe "tooth"?Thoughts on what's best....a Pirahna bar or a Tooth bar for my FEL? It will be used in pretty rocky ground probably 75% of the time. Thanks!
Dull is a relative word - when new my PTB was "sharp" - not anything like a razor edge, but you didnt want to leave your bucket raised at all! After 4 years, you still dont want to run into it with a shin, but at a 1/2" thick, it is not going to dull too bad - I will still run across a small tree and show it that not so dull edge!85Hokie....Yes, I'm referring to a backhoe type tooth bar. That's what I was thinking too as far as the rocky ground, but I have no experience with the PB. I was also thinking the PB would get dull after working a while in the rocky ground.
