Anyone ever replace the rear PTO shaft on a L3400 gear drive? Broke off flush after lowering a 60" tiller with too long of a driveshaft. Looks like it might be as easy as removing the 4 bolts and pulling the whole thing out and replacing the shaft. Might have a pressed on bearing which won't be an issue with the 20 ton shop press.
Thanks in advance.
Thanks in advance.
