F flyidaho Active member Equipment L 3301 HST Feb 28, 2017 415 203 43 IDAHO Jan 25, 2018 #21 Always an option, I'll see when I start using it how convenient it is as is. If I did extend it, I'd probably also put a dog leg in it.
C CapnDean Member Lifetime Member Equipment L6060,ZD1211 Feb 22, 2018 184 3 18 Gulfport, MS USA Mar 25, 2018 #22 I like following your write up. I would like to add a rear remote to my L3901. Looks like your kit would do it. Do you have part numbers of what all you had to order? I can have the hoses made up locally too.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,677 5,106 113 Sandpoint, ID Mar 25, 2018 #23 CapnDean said: I like following your write up. I would like to add a rear remote to my L3901. Looks like your kit would do it. Do you have part numbers of what all you had to order? I can have the hoses made up locally too. Click to expand... A factory rear remote kit would work better with less muss and fuss.
C CapnDean Member Lifetime Member Equipment L6060,ZD1211 Feb 22, 2018 184 3 18 Gulfport, MS USA Mar 27, 2018 #24 North Idaho Wolfman said: A factory rear remote kit would work better with less muss and fuss. Click to expand... I can do a lot of mussing and fussing for a thousand bucks
