Shekkie
LX2610, Virnig 60" Grapple, WoodMaxx TM-86H, Woods 60" BB/72”RB
Feb 12, 2022
183
305
Grafton, Ohio
I built your tractor on the Kubota site with the 3rd function kit and that’s the part number they included in the quote. It could be wrong but it’s all I could find. Good luck!
Ridelght
2022 Kubota L4060 Polaris Rangerxp800 Ford 3400
Feb 16, 2022
434
293
Thanks, i think it is. Never heard of that vendor before.
forky
L2501 HST 4X4 8N
Feb 23, 2021
254
253
Wisconsin
Spent an hour cleaning up the bottom of the driveway with the fel. Once things start to melt, I need to have a place for the water to run, or it will wash out expensive gravel.
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
140
247
St. Clair, MO.
Ground is still soft, but passable. Took advantage and used the bucket with piranha tooth bar on my little B to pull up (a dozen or so) small trees by the roots. Working on clearing about 2 acres of woods. Still waiting on the (bh70) backhoe.
jyoutz
Jan 14, 2019
2,499
1,606
Edgewood, New Mexico
My ground is nice and moist and a bit soft. This afternoon I used my rear blade to tip out a dozen older tree stumps that were always an obstacle to field mowing. There are still many more but I was able to remove some of the ones that were most in the way.
ctfjr
L3800HST
Dec 7, 2009
1,703
1,918
central ct
As I posted a few days ago, winter is over, I declared it done. So today I removed the snowblower from the tractor (omg thanks for pin releases on pto shaft!) and put it in the garage. When I turn on my outside sillcocks I'll take it outside for a good washing.
random
Nov 2, 2020
717
401
NC
Getting ready for spring planting - this weekend I tilled and hilled
Reactions: 11 users
Shekkie
Feb 12, 2022
183
305
Grafton, Ohio
I walked the property today. Still too soft for work. Stuck at 2.x hours but installed grill guard today. LEDs for the ROPS and wiring shows up tomorrow.
RalphVa
738
319
Charlottesville
Used the Woods 5 ft box blade today to take out some eons old sediment from the uphill side of an old maintenance road that we use as a trail. I just put a 1 by board underneath the right side to make it easier to work the adjustable lift arm to get a tilt on the left side of about 3/4 inch. Worked great. The 518 # Woods blade is just about right. Had to lift it up over some tree roots 3 or 4 places, but it mostly just broke them or dug them out.
Ridelght
Feb 16, 2022
434
293
I got stuck today as well. Thought I'd take some stuff to my Pond. This is an acre that's in front with its own mini hill. Now I need more dirt. Had to do the bucket scoop helper to get back up. LOL... Note to self-Industrial tires fill up with mud and become racing slicks.
Reactions: 9 users
Ridelght
Feb 16, 2022
434
293
Here’s the Kubota kit (I believe). 1 in stock.
Here’s another Kubota kit that appears to be in stock.
I believe WR Long makes the kits EA sells.
www.Ratchetrake.com
Anyone ever hear of Ratchet Rakes ? Neighbor told me about it. not sure though.
mdhughes
L3901DT
Dec 10, 2014
1,212
632
Ste Geneveive county, MO
What brand/ Model is that chipper if i can ask.
I have looked at Dr brands and some knock offs. Not sure wich is the best idea 🤔 any insight would be appreciated.
It is a WoodMaxx WM-8m. I have had it since Jan 2015 and I am very happy with it. I have some older post with pictures of a couple mounds of chips when I cleaned up after have 16 trees push down to make room for our garage.
Ridelght
Feb 16, 2022
434
293
Thank you !!
Ridelght
Feb 16, 2022
434
293
Thank you !!
I just looked them up. In NY and the current price on that unit is better than the others ive researched.
Thanks again. Rebuild kits are not crazy expensive too.
DaveFromMi
L3901, 5' Bush Hog
Apr 14, 2021
548
463
Indiana
I cut down some honey locust trees and put them in a pile. Drilled holes in the stumps and poured in some concentrated triclopyr. So far, haven't noticed any beet juice leaking out. Those trees are nasty.
Ridelght
Feb 16, 2022
434
293
I got stuck today as well. Thought I'd take some stuff to my Pond. This is an acre that's in front with its own mini hill. Now I need more dirt. Had to do the bucket scoop helper to get back up. LOL... Note to self-Industrial tires fill up with mud and become racing slicks. View attachment 76645
I think my was clean tractor may run away back to the dealer like a upset teenager after that fiasco. I was laughing though I'm sure my neighbor who's house is at that low level on the other side of the pond was laughing as well. Gotta laugh at youself.....I took that pic from up in my drive overlooking about 100 yards away. Those are deep ruts is my point. I drove up the road a mile to clean out the tires. there's a path out to the road to the right.
just dirt, My buddy up the road has a mini excavator and a dump truck. that may get graveled soon back to the area i want to remove trees. Shekki, you are a wise man. (y)
Sporto
B2601-1, FDR1660, RTA1258, BB1560, LR1672, PFL1242, MK Martin Snow Blower
Mar 20, 2021
46
39
Manitoba Canada
Just installed the factory Bucket level indicator on my B2601, as said in the You Tube video the dealer said that Kubota didn't make one, how ever the LA535 Loader indicator parts fits like a charm great add on
lynnmor
B2601-1
May 3, 2021
1,320
1,035
Red Lion
I installed the same, the only thing that might cause Kubota to say it doesn’t fit is that the bend in the indicator rod isn’t at the indicator when the bucket is level. Of course the mark you might use would be at a different location for each attachment.
Shekkie
Feb 12, 2022
183
305
Grafton, Ohio
I’m pretty impressed with the tractor and the grapple. I did a few things that were probably pushing the equipment a bit more than I usually would as a test and to get a feel for my new equipment and all is well.
The first pic is a tree that was too long for me to move anywhere due to living trees in the way but I wanted to see if I could lift it. A bit of a struggle but stable and I could move it if I had room. So I found that it can handle more than I need.
I moved a bunch of smaller trees and branches too. There is a bit of a learning curve to operating the grapple efficiently but I’m getting there. Today was to just get comfortable and familiar.
Some pics at the end of my destroyed trails the scope of the tornado damage I’m dealing with. These pics are about a tenth of my project.
Also notice in the pics that I mounted my LEDs to the ROPS. I gotta wire ‘em and tweak the angles for coverage but I’m happy with the placement. Also happy that I’m up to 5+ hours AND I only caused some light grass damage but no new ruts.
The ROPS are folded which I know is frowned upon but most of where I’m operating is around low branches so I don’t have much choice. Also my land is pretty flat so I don’t have much concern about tipping. With my wide tires I felt no stability issues. Flame away.
Reactions: 6 users
edritchey
A bunch of cute little Kubotas
Jul 19, 2014
1,075
745
Wellsville, PA
Got the grapple on the mini tractor to try to get into some softer areas I don't want to take a heavy machine into. You got to love these little tractors.
