Which oil for M80B
derschrauber
B1702DT
Mar 28, 2019
Switzerland
Hello and thanks in advance,
I own a Kubota B1702DT , and I want to change the hydraulic oil.
According to the label inside the unit the oil is M80B, the same used in front axle and transmission.
Can i use Kubota UDT Fluid or is it better to get an 80W90 ?
Thanks again.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Welcome to the OTT forum. You came to the right place to get answers.
If you had titled your post, "Which oil for B1702DT" you would have got a lot more answers and quicker.
975
You can use the UDT or universal tractor fluid (less expensive)
Gears won’t really care if you use these or 89/90 but hydraulics will do better with the newer style fluid.
I don’t think your tractor will get much benefit from more expensive UDT fluid but it will not hurt it at all.
The universal tractor fluid is what I use in the
L185 I own
