I was operating a B7300 yesterday with a tiller implement attached when the tiller froze with a jolt and engine stalled. As far as I could tell, a rock got jammed in there and caused the stall.
I lifted the tiller off the ground and restarted the engine fine, but now the PTO will not disengage.
The lever on the left hand side next to the seat has an option for 540 by moving it back and one for 900 by moving it forward and then a neutral in the middle. This lever will now only slide between the 900 and the neutral section and will not got down to 540. Even when sliding to 900, you don't get that little click/jolt like you can feel it engage something as it used to.
The lever still has to be in the neutral position and the clutch depressed to get the tractor to start so I know it's depressing the electrical pins correctly.
The PTO just turns constantly now even with the clutch depressed. The only way to get it to stop is to turn off the tractor.
HELP PLEASE!
Unfortunately, this is my father-in-law's machine that I was borrowing and I don't want to be disowned from the family.
HELP PLEASE!
